Dual master cylinder and keeping drums
GCF
I am in the process of changing the master cylinder on my 521 to a dual reservoir master but keeping the drums all around.
I have this new master from what I believe an early 70s 510. I know I need to change the residual valves to keep 10 lbs in the front and rear. Am I able to buy internal parts for these? Or could I remove both residual valves and run external valves in each line?
Notice the rubber valve for the front has two extra slits in it (red lines in the photo).
  • Replies 7
I am installing the same master on a 71 521 that I am also installing a Mike Klotz disc brake kit.
IK had to open up the hole in the firewall to except the new 3/4" dual reservoir master cylinder.  Like mentioned above the new master is metric 10mm-1 and the line nut for the old master is 3/8"-24.  What I did is made a new line to go from the new master cylinder to the tee.  The tee line nut is 3/8"-24 and the master line nut is 10mm-1.  This way I did not have to buy or use any adaptors.
Since I am doing front disc I pulled the rear line from the Tee (4 way) and tweaked it to screw into the Wilwood proportioning valve.  Both inlet and outlet on the proportioning valve are 38"-24 so I made a second new line from the rear port on the master to the inlet on the proportioning valve again 3/8"-24 line nut on one end and 10mm-1 line nut on the other end.
Where the 521 hard line connected to the hydraulic hose for the caliper I used a tubing cutter with the grooved wheel for close cutting and cut the double inverted flare off removed the 38"-24 line nut and slid a 10mm-1 line nut on and did a new doulbe flare.  The hard line on both front sides now screw into the metric calipers with no adapters.
I will take pictures of the new lines tomorrow when I am finishing up the disc brake brake install.
2 hours ago, Crashtd420 said:
Is it possible to use the residual valve out of the original single master cylinder?
Wouldnt that be a 10lb valve too?
Good thought. Ill take it apart and see if its the same.
I am running all new lines so shouldnt have any issue adapting to metric. I noticed the threads were different but didnt know what size it was so thanks for telling me. Where can i find info on the Mike Klotz disc brake kit? Think i might have seen a thread on it. Maybe while im at it.......
On 8/19/2021 at 2:52 PM, Crashtd420 said:
I'll throw this here ....
Best brake line flare tool in my opinion... perfect every time even I tight places.....
https://www.amazon.com/dp/B06XPRVCPV/ref=cm_sw_r_cp_apa_glt_fabc_FJX003MBCRA33SJ9YE7E?_encoding=UTF8&psc=1
I bought the 3/16" and the 1/4" models of these off of Amazon and the day after I ordered the 3/16 tool they went up to $52 from$37.
Edited by Charlie69
