shawninvancouver Posted July 29, 2021 Report Share Posted July 29, 2021 74 260 wiper motor just clicks when i turn on the wipers.. i assume the motor is seized.. the motor is out and does not spin.. any way to get it to loosen up and SPINNNN??? Quote Link to comment
datzenmike Posted July 29, 2021 Report Share Posted July 29, 2021 It's gear reduction so don't twist the arm. If it has plastic gears they will probably strip. Take it apart and see if you can twist the motor armature itself. May just be the brushes corroded onto the contacts. Got nothing to loose at this point. Quote Link to comment
shawninvancouver Posted July 30, 2021 Author Report Share Posted July 30, 2021 ok.. motor is apart.. magnets and inside of motor look ok... can i open the gear side of the unit where the plastic white gear is?? and how do you get those magnets back in with dental floss?? Quote Link to comment
shawninvancouver Posted July 30, 2021 Author Report Share Posted July 30, 2021 what else would be causing it to click when i try to turn it on?? Quote Link to comment
yenpit Posted August 2, 2021 Report Share Posted August 2, 2021 The late 240Z & 260Z should have a relay mounted to the wiper motor. Open that up to clean. Sometimes the wiper wheelboxes (pivots) seize up.....have you tried to rotate those.........move the linkage? Quote Link to comment
