Headliner questions
I just hung the headliner today from the bows, my question is about how far up the roof apron does the headliner get glued, is suppose to be glued to the flat of the slope on the apron or just touch bottom curve before beening glued to the pinch weld?
Thanks
  • Replies 7
Good question.  I will be getting to this soon.
Any evidence of glue residue there now?  I will have to look on my car.
I would think you could only glue on the pinch weld and let the material naturally wrap over the curve, but gluing a bit on the curve might help locating it.
  • Thanks 1
Hopefully only glued along the flange, NOT on the 3+ inch wide rail where you were pointing with the pen!  As mrbigtanker said, the headliner "floats" & hangs from the bows everywhere in the middle, except where it is glued all around at the front, rear & side flanges.
Do you have the necessary "hardware" at the top of the C pillar?  There was a piece of masonite at the top that gave it the crisp straight edge, where it overlaps the headliner.  I don't remember from your thread if you bought as a mostly complete car or in pieces.....??  I will have the "hardware".............PM if you need!  I have seen upholstery shops try other approaches, which usually look like crap!
He did, I tried to tell him. Why ask for help then don't use it. oh well.
No I did not, read the text,
On 6/14/2021 at 4:50 PM, grannyknot said:
I applied glue to the bottom curve and both sides of the pinch weld
and yes I have the the hardware.
  • Confused 1
