rosso Posted April 24, 2021 Report Share Posted April 24, 2021 I need to get ready for the road trip to Powerland - I thought I better check out the spare. I lowered it down and it is a 155R12. I said what the? Is this the correct size for a 510 wagon spare? I thought all 510 were 13" - but I never had a wagon before. It is about the right diameter compared to the 195/60-14 I have on the car. It is a rather old tire, so I am going to buy one tire no matter what - the question is do I go with the 155R12 or is it better to have a 165R13. And will that fit up in the spare wheel space under the rear of the car? If I go with 13" I will need to buy a steel wheel also. Quote Link to comment
datzenmike Posted April 24, 2021 Report Share Posted April 24, 2021 5.60 X13 is stock Diameter is key. As long as the 12" and tire is the same as the 195/60R14 you are running. The 195/60R14 is 23.21" tall measure the spare but I doubt it is close. A 195/70R12 tire is an exact match (height and width) to the 195/60R14s you have.. Quote Link to comment
rosso Posted April 24, 2021 Author Report Share Posted April 24, 2021 Thanks Mike, I was trying to confirm that the 12" was something a previous owner put on - not stock for the wagon. Given how much I have spent on the car, and it being a spare tire, I was thinking of saving the $50 cost of buying another steel wheel. Maybe the 165/13 will be cheaper than the 155/12 to offset the new wheel a bit. You going to Powerland? I missed meeting you at the last Canby. Cheers, M Quote Link to comment
datzenmike Posted April 24, 2021 Report Share Posted April 24, 2021 The 1200 came with 12" rims. 6:00 x 12 with 155/80R 12 tires. Probably won't go to Powerland. Need to work on my Datsun. Got half way to Calgary last summer and turned back because of noise in the rear.. Quote Link to comment
rosso Posted April 24, 2021 Author Report Share Posted April 24, 2021 That could be the answer, the previous owner had a 1200 coupe and maybe just stuck one of the tires under the wagon to make do. Sorry to hear I will again miss meeting you at Powerland. 😞 Quote Link to comment
Duncan Posted April 27, 2021 Report Share Posted April 27, 2021 The 12" rim might not clear the brake calipers. You might check that out before buying a 12" tire. Quote Link to comment
rosso Posted April 27, 2021 Author Report Share Posted April 27, 2021 Definitely. Even the 13" stock steel will not clear the ZX brakes in the front. So if I ever have a front flat I will need to put the spare on the back, then move the back to the front flat. Not ideal, but I can live with that since no larger tire or wheel will fit under the car easily. 1 Quote Link to comment
