justaguywitha720 Posted April 21, 2021 Report Share Posted April 21, 2021 hi guys i am in need of a 720 output shaft. the one i have is letting oil leak out of the trans beccause it is scored. does anyone know where i can get a new one? 1 Quote Link to comment
datzenmike Posted April 21, 2021 Report Share Posted April 21, 2021 There are two and they depend on the length of your 5 speed. The transmissions are either 26" or 31.5" so the primary driveshaft to the transfer case will be longer or shorter by 5.5". You will need to specify the length you need. At some point smaller U joints and driveshaft tubes were used and later ones are larger. This shouldn't matter as the splines and seals are the same. You might also find it easier to just swap the front part with the spline. Again there were large and small U joints so it would have to match yours. I think the change was probably '83. 1 Quote Link to comment
Lockleaf Posted April 23, 2021 Report Share Posted April 23, 2021 The yoke matches the yoke from most other datsuns and even most subarus. You should be able to swap a different one on. Also many drive shaft shops have the ability to weld up damage and turn piece back down to the correct diameter. Third you may be able to put a repair sleeve on it depending on the damage. 1 Quote Link to comment
Stinky Posted April 26, 2021 Report Share Posted April 26, 2021 (edited) What he said....build it up, the turn. It down. There are a bunch of dif coatings out there that will work. If the shop cant do it, talk to a machinist and a coatings place... Edited April 30, 2021 by Stinky 1 Quote Link to comment
butter fingers Posted April 27, 2021 Report Share Posted April 27, 2021 i can grab one from the 84 in the yard and make it easy ! lol 2 Quote Link to comment
justaguywitha720 Posted April 28, 2021 Author Report Share Posted April 28, 2021 Hey man if you have one I would like it if you are interested in getting rid of one On 4/26/2021 at 6:32 PM, butter fingers said: i can grab one from the 84 in the yard and make it easy ! lol 1 Quote Link to comment
butter fingers Posted April 28, 2021 Report Share Posted April 28, 2021 hi , send me a length measurement of the shaft , measure center to center on the shaft u-joint please . butter fingers 2 Quote Link to comment
