Tank. Posted March 23, 2021 Report Share Posted March 23, 2021 Does anyone know if there is a pinion flange for an H190 that changes the u-joint from datsun to a spicer 1310? The reason I ask is I am having a 1 piece driveshaft made for my Ka24de 5spd swap 620 and I can get a 1310 style slip yoke for that but can’t find a comparable pinion flange. Quote Link to comment
datzenmike Posted March 23, 2021 Report Share Posted March 23, 2021 Try a shop that only specializes in drive shaft repair. Quote Link to comment
Tank. Posted March 23, 2021 Author Report Share Posted March 23, 2021 7 hours ago, datzenmike said: Try a shop that only specializes in drive shaft repair. That’s my next step, I have a really good one about an hour away. Quote Link to comment
datzenmike Posted March 23, 2021 Report Share Posted March 23, 2021 I had a slip joint problem when traveling. Found a shop and he sent me to a wrecking yard for a Chevy unit and some U joint measurements. He custom modified it to fit using the 71B trans spline and re drilled the driveshaft flange, welded and balanced it. Now has Chevy Spicer U joint. Did it on Saturday for cash. 1 Quote Link to comment
Stoffregen Motorsports Posted March 23, 2021 Report Share Posted March 23, 2021 Jesse at High Angle Driveline will make any flange. Quote Link to comment
Tank. Posted March 23, 2021 Author Report Share Posted March 23, 2021 3 hours ago, Stoffregen Motorsports said: Jesse at High Angle Driveline will make any flange. Good to know, thanks! 1 Quote Link to comment
