1lo620 Posted March 20, 2021 Report Share Posted March 20, 2021 Ok so I got no brakes lights on my 620. I replaced the brake switch thinking an easy fix. But that did not seek to work. All other lights work front and back. Any ideas Ratsun members? Quote Link to comment
datzenmike Posted March 21, 2021 Report Share Posted March 21, 2021 Which one '74 or '77????? Does your horn work??? If not the fuse is blown. It's the 15 amp left side closest the dash. Quote Link to comment
MikeRL411 Posted March 21, 2021 Report Share Posted March 21, 2021 Or 2 burnt out bulbs. I had the same problem many years ago. After tracing the wiring etc. I checked the bulbs just for the hell of it. DOH ! Don't remember how many hours I had wasted, but I know every where my wiring harnesses hide. Quote Link to comment
datzenmike Posted March 21, 2021 Report Share Posted March 21, 2021 If the turn signals work then the bulbs are ok. Signal and brake take turns sharing the same filament. Quote Link to comment
1lo620 Posted March 22, 2021 Author Report Share Posted March 22, 2021 7 hours ago, datzenmike said: If the turn signals work then the bulbs are ok. Signal and brake take turns sharing the same filament. Well dont I feel foolish...it was a blown fuse. Problem fixed. I looked at them Just not good enough. Thanks Mike..sure I will be back again with questions..soon. Quote Link to comment
datzenmike Posted March 22, 2021 Report Share Posted March 22, 2021 It's a cheap easy fix. Quote Link to comment
