Skoob Posted December 20, 2020 Author Report Share Posted December 20, 2020 I just ordered the H4 conversion for the headlights...F the Bs... As for the temp, the saga continues...(until my aftermarket gauge gets here) Quote Link to comment
Icehouse Posted December 20, 2020 Report Share Posted December 20, 2020 Did you put the S13 temp sender in and it's still not reading? Quote Link to comment
banzai510(hainz) Posted December 21, 2020 Report Share Posted December 21, 2020 the passenger side light is used to trigger the H4 Harness. it has to work but it will trigger at 9 volt 9 volts at all 3 prongs???? there has to be corrosion some where. Either there is a bad connection or fusses corrosion. You Clean all of them? with light switch off you not even using the relay and your getting 9 volts at the prongs. so measure will a Volt meter at battery . battery post then down to the starter lug(is it tight?) then up to the fuse box., one side of the lamps fuses should be 12volts or same as the battery. this is simple. Quote Link to comment
Skoob Posted January 5, 2021 Author Report Share Posted January 5, 2021 Thank you for your help. I decided to just run a separate fuse block to run all my new stuff to; fan, running lights, various electronics. High Beams still stuck on probably the relay even after cleaning it and my switch. So I throw yellow fogs in the middle and called it a day. Thanks again for the help Quote Link to comment
datzenmike Posted January 5, 2021 Report Share Posted January 5, 2021 The hi/low relay will not work if you do not have parking, clearance, marker, license, dash lights. It's the first pull out position on the headlamp switch. Without this working, the relay is not powered and stays in the default position (off) which is hi beams. Quote Link to comment
