City Hunter Posted December 1, 2008 Report Share Posted December 1, 2008 I figure there has to be a easy conversion. I just did this with my lancer and it was basically a bolt in conversion. I'd rather run a cable and the 240sx tb instead of shaft and a conversion. Quote Link to comment
240ADAM Posted December 1, 2008 Report Share Posted December 1, 2008 I was going to do the same, but I figured for 36 bucks i could buy the TB adapter from ArizonaZcar and not mess with it. The stock linkage works fine for me. Quote Link to comment
City Hunter Posted December 1, 2008 Author Report Share Posted December 1, 2008 I'll have to pull ym pedal off one of these days and go check out some older nissans from the 80s. If they are anything like mitsubishi, they retained teh stock mounting holes. Quote Link to comment
Skib Posted December 1, 2008 Report Share Posted December 1, 2008 [edit] found it Quote Link to comment
72240z Posted December 1, 2008 Report Share Posted December 1, 2008 Beat me to it lol. Quote Link to comment
City Hunter Posted December 1, 2008 Author Report Share Posted December 1, 2008 that really makes me want to keep ym z and turbo it. hmm, I should put this n42 intake on and see if my fuel injection actually works. Quote Link to comment
Llittle_Llama Posted December 1, 2008 Report Share Posted December 1, 2008 so damn clean.... Quote Link to comment
hughdogz Posted December 2, 2008 Report Share Posted December 2, 2008 ^^^ Austin Hoke's 240Z. I totally dig it except for where the intake air temp sensor was placed at the stock cold start injector location...it probably heat-soaked like a mo-fo. :confused: What were we talking about? Oh yeah City Hunter, you can buy that little dealie-o that locks down and adjusts the cable linkage aftermarket. Not exactly sure where though... Quote Link to comment
SHADY280 Posted December 2, 2008 Report Share Posted December 2, 2008 its really quite simple to convert, msa has a kit, but its really just a cable that mounts where the linkage goes thru, then where it attaches to the pedal, is where the cable gets attached to, on the firewall there is also an adjuster. then run the cable and hook it up. the kit is from locar, most hotrod guys use it. i did on a recent 350 into a zx build i just did. if you need more travel, heat and bend the pedal upward to get more travel.. carbs require more, so i had to do this. Quote Link to comment
