adwolf``` Posted September 4, 2020 Report Share Posted September 4, 2020 Does anyone know if I can use 26mm thick rotors on the Sumitomo 4pot calipers? Or do I have to use 30mm? Slowly getting the bits for a brake upgrade on the 510. Sorry if this has been discussed I can't find any information. Quote Link to comment
Lockleaf Posted September 4, 2020 Report Share Posted September 4, 2020 I would imagine if you put a 2mm spacer behind each pad the caliper would never know the difference. And i think you would have to push a 510 pretty seriously to make it need 30mm worth of brake fade resistance. 1 Quote Link to comment
adwolf``` Posted September 4, 2020 Author Report Share Posted September 4, 2020 Thanks heaps didn't even consider that. Quote Link to comment
iceman510 Posted September 4, 2020 Report Share Posted September 4, 2020 You may not need the spacers. You just have to monitor your pad wear and confirm you don't have so much piston travel when the pads are low that the piston is too far extended. You could test this with spacers the thickness of the pad (or thickness + 2mm pad material which is what you are supposed to use a pad wear limit) backing plates and check piston travel when clamped . Quote Link to comment
Icehouse Posted September 4, 2020 Report Share Posted September 4, 2020 We run those calipers on S12 V6 struts with z31 rotors on our enduro 510. Not sure the thickness but I'm sure it''s less then 30mm I will measure tonight. We've worn the pads down to metal and never had an issue. Quote Link to comment
iceman510 Posted September 4, 2020 Report Share Posted September 4, 2020 Now that is getting value from your brake pads. 😆 Quote Link to comment
