Bearcrawl Posted August 28, 2020 Report Share Posted August 28, 2020 So the 411 has been running like garbage when it's cold. Much better when it heats up but it was taking forever to heat up. Trying to check of some simple stuff I decided to check out the thermostat and see if it was somehow stuck open. When i opened up the tower where I expected it to be there was nothing there. Am I missing something... or is something missing? Assuming theres supposed to be a thermostat in there, the spring would go down right? Was expecting to be able to reference the therm that I was expecting to see. Thermostat I have seems to fit fine but I will need to make a gasket. Thanks in advance Quote Link to comment
datzenmike Posted August 28, 2020 Report Share Posted August 28, 2020 My '74 710 was really slow slow warm. This is the original thermostat... Use the thermostat cover for a template and grab an old cereal box, I prefer Cheerios but All Bran is ok too. Trace it out Get a round hole punch from a dollah store. And a pair of good scissors. Nibble a hole large enough to get the scissors in... You can make anything. This is the oil pump to timing cover gasket... My thermostat, oil pump and water pump all have cereal box gaskets. Quote Link to comment
Bearcrawl Posted August 28, 2020 Author Report Share Posted August 28, 2020 Thanks for the quick reply Mike. Appreciate your style. So there should have been a thermostat there? Spring down? Thx again. Quote Link to comment
datzenmike Posted August 28, 2020 Report Share Posted August 28, 2020 Yes it should have a 180F thermostat and spring down so the hot water can get to it. I think it should also have a jiggle valve on the thermostat but you'll have to check. If you don't have a coolant by pass the jiggle valve will do about the same thing. It allows a small flow of coolant through so the thermostat can sample the temperature. Otherwise the water around the thermostat is stagnant and remains cold. Quote Link to comment
Bearcrawl Posted August 28, 2020 Author Report Share Posted August 28, 2020 Yeah Buddy... It's even got a jiggle valve. Honestly, was curious what the hell that thing was. Much appreciated. Quote Link to comment
datzenmike Posted August 28, 2020 Report Share Posted August 28, 2020 I see it now. Quote Link to comment
Eiles Posted August 31, 2020 Report Share Posted August 31, 2020 This is a very helpful discussion. So good to have such knowledgeable people only a keyboard away. 😄👏 Quote Link to comment
datzenmike Posted August 31, 2020 Report Share Posted August 31, 2020 You're never alone with your Datsun. Quote Link to comment
Bearcrawl Posted August 31, 2020 Author Report Share Posted August 31, 2020 Sure Did help me. Thanks again Mike. Although I must confess. I cheated and bought a sheet of gasket material..... Dashboard nearly fully functional New speedometer cable came today. Last step toward a functional dash. Get ready for that post.... Quote Link to comment
datzenmike Posted August 31, 2020 Report Share Posted August 31, 2020 I also have a sheet (now) of gasket that I used for my R-1 carbs. They seal with that rubber ring but I wasn't taking chances. The felpro is thinner. Cereal box was for when no time to go into town to get something else and I refuse to be held up by that.. Quote Link to comment
Bearcrawl Posted August 31, 2020 Author Report Share Posted August 31, 2020 You are waaaaaay better at that than I.... Quote Link to comment
datzenmike Posted August 31, 2020 Report Share Posted August 31, 2020 From years of time but no money AND liking to learn to do your own stuff. Quote Link to comment
MikeRL411 Posted September 26, 2021 Report Share Posted September 26, 2021 411 maintenance equals patience and imagination. I have engine parts from Buick 455 cu V8 [Thermostat by pass hoses repurposed], KIA Sephia [thermostat housing] and Ford Police Interceptor Cop car [Heater hoses, they are Silicon]. Also various replacement hose assemblies that I cannibalise to fit the heater and engine preheat hoses that did not last 65 years. You CAN make them last ! Quote Link to comment
