matrophy Posted July 25, 2020 Report Share Posted July 25, 2020 I marked my driveshaft before removing it but one mark must have rubbed off of the diff flange while I was Dremeling off one of the D-bolts that was rounded off. I'm planning on trying it installed in the 4 different positions and test driving at a range of speeds unless there is some other way of knowing that it is installed back the way it was without doing all of that work. 1 Quote Link to comment
Stoffregen Motorsports Posted July 25, 2020 Report Share Posted July 25, 2020 The position on the diff flange does not matter, as long as it bolts up. If it is a two piece shaft with a pillow block, the phasing in the middle of the shaft matters. Quote Link to comment
datzenmike Posted July 25, 2020 Report Share Posted July 25, 2020 3 hours ago, matrophy said: I marked my driveshaft before removing it but one mark must have rubbed off of the diff flange while I was Dremeling off one of the D-bolts that was rounded off. I'm planning on trying it installed in the 4 different positions and test driving at a range of speeds unless there is some other way of knowing that it is installed back the way it was without doing all of that work. I think the bolt pattern on the differential flange is in a rectangle, so you only have 2 choices. Unless you have a 4x4 with a slip yoke like above it really won't matter. 1 Quote Link to comment
matrophy Posted July 25, 2020 Author Report Share Posted July 25, 2020 1 hour ago, Stoffregen Motorsports said: The position on the diff flange does not matter, as long as it bolts up. If it is a two piece shaft with a pillow block, the phasing in the middle of the shaft matters. Well that's good to hear. 2 Quote Link to comment
