TheBirdistheWord Posted June 5, 2020 Report Share Posted June 5, 2020 (edited) I swear there used to be a sticky with this information. Uninstalling and installing seems relatively straight forward. Unscrew/clip all of the things, slide it out of the bottom part of door. Can anyone confirm if I tape the window in place in the "up" position or is it easier to roll it down? I'm asking because the roller gears are definitely stripped, and if I roll it down it may now be going back up again. Edited June 5, 2020 by TheBirdistheWord Quote Link to comment
TheBirdistheWord Posted June 6, 2020 Author Report Share Posted June 6, 2020 I took a stab at it with window taped in the up position. Worked out fine. Quote Link to comment
Jesse C. Posted June 7, 2020 Report Share Posted June 7, 2020 I just removed the glass out of the door. Makes it easier to replace the mechanism and a good chance to inspect all the other goodies without trying to juggle glass at the same time. Quote Link to comment
yenpit Posted June 12, 2020 Report Share Posted June 12, 2020 You should also at least check or replace the C felt channel that the glass moves up & down in! When that felt channel gets old, it breaks up into chunks & jambs the glass from sliding smoothly, so that is one reason why the regulators wear out/break. Replacing the C felt channel is straight forward, but labor intensive per door, cuz gotta take glass out etc etc.............. 1 Quote Link to comment
