matrophy Posted May 24, 2020 Report Share Posted May 24, 2020 Bought cap and rotor from RockAuto for '86 720 with z24 and the rotor is too tall and doesn't lineup with screw hole in dist shaft by about 1/2". I assume that the cap that came with it wouldn't work with a shorter rotor. Are there 2 sizes of caps and rotors possible for these trucks? My wiring harness matches 1984 exactly so I'm wondering if my distributor is from an earlier year as well. 1 Quote Link to comment
Charlie69 Posted May 24, 2020 Report Share Posted May 24, 2020 When I buy a cap and rotor now days I order the cap and rotor kit so ia ma sure the cap and rotor match. I quit buying from Rock Auto for this reason I would get the correct part # box but the part in the box was wrong. Quote Link to comment
matrophy Posted May 24, 2020 Author Report Share Posted May 24, 2020 I did order the kit. There are no markings on the parts so I can't tell if the wrong part is in there. In your experience are there 2 sizes of these caps/rotors for 720s? Where do you buy yours from? I am not married to RockAuto for sure although now I have a store credit... 1 Quote Link to comment
Charlie69 Posted May 25, 2020 Report Share Posted May 25, 2020 I buy most of my parts from NAPA. I could not say if there are 2 heights or not. I have worked with Z20 and Z24 engines in the later 720s. I have also had at least 10 or 12 1980 720s with the L20B engines. I have purchased an 81, 82, and 83 but none of the had engines when I got them. My 84 and 85 720 2wd king cab STs both had Z24s in them. Quote Link to comment
matrophy Posted May 25, 2020 Author Report Share Posted May 25, 2020 Thanks. I am ordering a set from NAPA. I'm assuming that RockAuto put the wrong thing in the box or whatever 1 Quote Link to comment
matrophy Posted May 26, 2020 Author Report Share Posted May 26, 2020 Here's some info I got from a Facebook poster who works at a Nissan dealer (so I'm not crazy): There are THREE 720 distributor caps 1) 1980 L20B 2) 1981 Z22 3) 1982-1983.0 Z22 1983.5-1986 Z20, Z24, & Z24i There are FOUR 720 rotors 1) 1980-720 2) 1981 Z22 3) 1982-1983.0 Z22 1983.5-1986 Z20, Z24 4) 1985.5-1986 Z24i 1 Quote Link to comment
Charlie69 Posted May 27, 2020 Report Share Posted May 27, 2020 On 5/24/2020 at 9:09 PM, matrophy said: Thanks. I am ordering a set from NAPA. I'm assuming that RockAuto put the wrong thing in the box or whatever Rock Auto sells old stock from various automotive warehouses, Chances are that Rock Auto did not do it, it was probably mixed up somewhere in the 30 to 40 years the parts have been transfered from one warehouse to the auto parts store and back again. Quote Link to comment
MaddieCycle Posted July 29, 2020 Report Share Posted July 29, 2020 I had this problem too with the rotor/distributor on my '86 KC with a Z24, the truck was manufactured in June 1985. I also had a problem with the air filter not fitting properly. I got all of this stuff at O'Reilly. I forget how but I figured out that I needed to order for '85 model and when I got those parts they all fit perfectly. 1 Quote Link to comment
Charlie69 Posted July 29, 2020 Report Share Posted July 29, 2020 It is I believe the difference in carbureted and throttle body. Also the Z20 takes a different cap and rotor on some models. Quote Link to comment
