Duncan Posted August 2, 2020 Report Share Posted August 2, 2020 1 minute ago, datsuntech said: @Duncan What engine are we talking about? I'm in the middle of a timing chain fiasco on the L20B in my wagon... Quote Link to comment
datsuntech Posted August 2, 2020 Report Share Posted August 2, 2020 (edited) 11 minutes ago, Duncan said: I'm in the middle of a timing chain fiasco on the L20B in my wagon... If you have a gasket then you should replace it with a gasket. That's quite the gap to fill. I've never been able to seal a L-series pan gasket reliably since they stopped making thick paper gaskets. The cork/rubber just always seems to leak. Next time I pull a pan I'm going to try just RTV and see how that does. Can't be worse. Edited August 2, 2020 by datsuntech Punctuation and Capitalization 1 Quote Link to comment
Duncan Posted August 2, 2020 Report Share Posted August 2, 2020 13 minutes ago, datsuntech said: Next time I pull a pan I'm going to try just RTV and see how that does. Can't be worse. I just pulled the front 4 bolts out to pull the front cover off. I'm just going to cut the front section off another gasket and glue it down. The pisser is the pan didn't leak previously.. 1 Quote Link to comment
Stoffregen Motorsports Posted August 3, 2020 Report Share Posted August 3, 2020 22 hours ago, Duncan said: Just curious here, but do you guys use this stuff in place of a gasket, or do you use this as a gasket sealer? I use it in place of the gasket. Many new engines come with only RTV sealing the oil pan, timing covers, etc. The "right stuff" is great for sealing steel pans to engine blocks. Quote Link to comment
datsuntech Posted August 3, 2020 Report Share Posted August 3, 2020 59 minutes ago, Stoffregen Motorsports said: I use it in place of the gasket. Many new engines come with only RTV sealing the oil pan, timing covers, etc. The "right stuff" is great for sealing steel pans to engine blocks. True, but newer engines have a groove that the RTV seals in. They are designed for this. Not sure how a perfectly flat surface or one not designed for it will seal properly. Quote Link to comment
Stoffregen Motorsports Posted August 3, 2020 Report Share Posted August 3, 2020 Ok, well I do it all the time and it works so I can't argue the science. It just works. 1 Quote Link to comment
