Glovebox inset
Gery
My glovebox insert was pretty rotten, and I got tired of stuff falling out from under the dash.  My solution won’t apply to purists, but for those looking for function at low cost, this might help.  I took a plastic  ammo box from Harbor Freight (less than $5), cit the top and upper lid off, and it has a pretty good vertical fit in my 620. It is not as wide as the original insert but I used the extra space behind the glovebox door to mount a couple of charger outlets.  It is much sturdier than the cardboard originals and fairly easy to pop in and out.  Because it is abs plastic, I could even mount a light very easily.  If anyone is interested I will take a photo.
  • Replies 4
