521 hot spark dizzy swap
Hey I just did a dizzy swap to get rid of my dual point distributor I bought the hot spark dizzy with the coil for 130$.It was a easy swap only 2 wires to reconnect and a slight mod to the timing plate . It already runs much smoother now and I haven’t even put a timing light on if yet
  • Replies 9
Changing is a pain, we used to file them down too but then they have to be set correctly. As they wear down the timing changes toward retarded as the gap opens. They will probably last  forever as there are no moving parts on it.
i used to keep a spare set of points in the glove box as well as a piece of 600 grit sandpaper
I changed a few sets on the side of the road
running petronix now have had it since 2011 with no issues
