frankendat Posted April 14, 2020 Report Share Posted April 14, 2020 Good day, I seek the factory service manual that provides detailed instructions on disassembly/reassembly of the "shorty" 5-speed found in 4x4 720's. The search function on ratsun and search through Google have uncovered many manuals, the free ones I have downloaded, but none that I have found, specifically provide detailed transmission information. 2 Quote Link to comment
frankendat Posted April 14, 2020 Author Report Share Posted April 14, 2020 Good day, Checking to see if anyone will upload, or can show me the way, to acquire the factory manual that provides step by step instructions for disassembly/reassembly of the 720 "shorty" 5sp. I have located/downloaded service manuals on ratsun and the nicco site, but have not found the desired information. Thanks in advance 2 Quote Link to comment
datzenmike Posted April 15, 2020 Report Share Posted April 15, 2020 Look for a FSM (factory service manual) for your year transmission. The 71B are all close to the same, a shorty just has a shorter mainshaft and rear case. 3 Quote Link to comment
Dguy210 Posted April 15, 2020 Report Share Posted April 15, 2020 (edited) 35 minutes ago, frankendat said: My computer froze up while posting this question and I ended up posting it twice. The same post is in the 720 forum. Please feel free to delete this thread. Thank you 13 minutes ago, datzenmike said: Look for a FSM (factory service manual) for your year transmission. The 71B are all close to the same, a shorty just has a shorter mainshaft and rear case. http://datsun1200.com/modules/mediawiki/index.php?title=71-Series_Transmission This link is for a full 1982 720 factory service manual, if you have a different year let me know and I will look if I have that. https://www.nicoclub.com/service-manual?fsm=Datsun 720 Factory Service Manual.pdf Here is the 1980 720 FSM https://drive.google.com/file/d/0B02OHcVM-KXXQ1Bpb0JudVFPQUU/view Also this Transmission manual book, which is for the 71B 4spds, Datzenmike would know what the differences are on that and the 5spds.: https://drive.google.com/file/d/0B02OHcVM-KXXaHBiRVUxcTE0M3M/view Edit: And, I actually happen to own the 1980 4wd FSM, I will look through and get picks for the transmission momentarily. Edited April 15, 2020 by Dguy210 4 Quote Link to comment
Dguy210 Posted April 15, 2020 Report Share Posted April 15, 2020 1980 720 4x4 Manual Transmission section of the Factory service manual. Did a real quick scan with my phone and turned it into a PDF. Hope it helps https://drive.google.com/open?id=1iXq4MpCzwtcTxCuspasMPWtWe3nLMgdA 3 Quote Link to comment
Dguy210 Posted April 15, 2020 Report Share Posted April 15, 2020 1 hour ago, frankendat said: Good day, I seek the factory service manual that provides detailed instructions on disassembly/reassembly of the "shorty" 5-speed found in 4x4 720's. The search function on ratsun and search through Google have uncovered many manuals, the free ones I have downloaded, but none that I have found, specifically provide detailed transmission information. Go check out the other thread you started. I just scanned and posted that section of the 1980 720 4x4 factory service manual for transmission. I will link here to. https://drive.google.com/open?id=1iXq4MpCzwtcTxCuspasMPWtWe3nLMgdA 1 Quote Link to comment
frankendat Posted April 15, 2020 Author Report Share Posted April 15, 2020 Dguy 210 THANK YOU When I started reading your first post, I thought I had already downloaded and read that stuff (the datsun1200 site and the 82 manual are no-go) BUT then I came to the Google Drive links for the 80 FSM and Transmission manual---AWESOME, the kind of candy I was looking for, Thanks again (hopefully with this info, the Dime articles and a sprinkle of Youtube videos I will figure this transmission) The transmission I want to rebuild is a "shorty" 5sp from a 1985 4x4 720. 3 Quote Link to comment
Dguy210 Posted April 15, 2020 Report Share Posted April 15, 2020 3 minutes ago, frankendat said: Dguy 210 THANK YOU When I started reading your first post, I thought I had already downloaded and read that stuff (the datsun1200 site and the 82 manual are no-go) BUT then I came to the Google Drive links for the 80 FSM and Transmission manual---AWESOME, the kind of candy I was looking for, Thanks again (hopefully with this info, the Dime articles and a sprinkle of Youtube videos I will figure this transmission) The transmission I want to rebuild is a "shorty" 5sp from a 1985 4x4 720. Good luck with it! I'm actually running that same transmission just 2wd version (only difference being the speedo cable) behind my KA24 swap 1200. Strangely enough I actually have every pickup FSM from 75-83, but no 82 which is the scanned one online. 2 Quote Link to comment
datzenmike Posted April 15, 2020 Report Share Posted April 15, 2020 I'll sanitize it and merge into this one. 3 Quote Link to comment
frankendat Posted April 17, 2020 Author Report Share Posted April 17, 2020 thank you 2 Quote Link to comment
awilson40 Posted April 20, 2020 Report Share Posted April 20, 2020 On 4/14/2020 at 9:05 PM, frankendat said: Dguy 210 THANK YOU When I started reading your first post, I thought I had already downloaded and read that stuff (the datsun1200 site and the 82 manual are no-go) BUT then I came to the Google Drive links for the 80 FSM and Transmission manual---AWESOME, the kind of candy I was looking for, Thanks again (hopefully with this info, the Dime articles and a sprinkle of Youtube videos I will figure this transmission) The transmission I want to rebuild is a "shorty" 5sp from a 1985 4x4 720. I can use the same thing, Thanks so much :) 2 Quote Link to comment
frankendat Posted April 22, 2020 Author Report Share Posted April 22, 2020 awilson40, awesome roadster! Not sure if you found the info. The "google drive" links, posted by Dguy 210 on April 14, have all requested information. Also, I seek to install a datsun engine in a non datsun application and am concerned about size. I would think an Indy Roadster would have specific size limitations. Do you know the smallest size engine bay, length, width, height that will accommodate a Z-block or an L-block datsun engine? 1 Quote Link to comment
