Lonewolf1990 Posted February 14, 2020 Report Share Posted February 14, 2020 Alright datsun fam I just ordered a Weber carb , I have a 77 620 with a LB20 engine stock, what are the tips and tricks to install also other question is what vacuum lines can I get rid off and i would still have to get my truck smogged later on is there a way to keep some vacuum lines installed so I’ll be able to pass smog Quote Link to comment
Stoffregen Motorsports Posted February 14, 2020 Report Share Posted February 14, 2020 1st tip - if using a two piece carb adapter, use loctite on all the hardware during install. These are notorious for coming loose and causing vacuum leaks. Quote Link to comment
Lonewolf1990 Posted February 14, 2020 Author Report Share Posted February 14, 2020 2 minutes ago, Stoffregen Motorsports said: 1st tip - if using a two piece carb adapter, use loctite on all the hardware during install. These are notorious for coming loose and causing vacuum leaks. Noted! Quote Link to comment
captain720 Posted February 21, 2020 Report Share Posted February 21, 2020 On 2/14/2020 at 8:36 AM, Stoffregen Motorsports said: 1st tip - if using a two piece carb adapter, use loctite on all the hardware during install. These are notorious for coming loose and causing vacuum leaks. And a super tiny bit of Gasgacinch on all the gaskets Quote Link to comment
Stoffregen Motorsports Posted February 21, 2020 Report Share Posted February 21, 2020 2 hours ago, captain720 said: And a super tiny bit of Gasgacinch on all the gaskets Or Threebond 1211. 1 Quote Link to comment
