Wiper issues
  • Replies 3
Does the windshield washer work? If yes then the fuse for it and the wiperis OK.
Are they stuck to the glass?
Can you hear the wiper motor running, is it making any sound?
Do the wiper arms move even slightly like they are trying??
If it’s anyrhing like my old D21, take the cowl off and inspect the linkage what where the motor attaches to. Mine used a “ball and socket” type joint and would pop off once and a while. Eventually had to replace the arm with the female portion (socket portion) as it was to far worn out. Motor would spin, but was disconnected so no wiper action. Hope this helps.
-Pidge
