Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 If you have an old burnt regulator just cut the regulator off an use the plug to make the jumper 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 1 minute ago, Crashtd420 said: If you have an old burnt regulator just cut the regulator off an use the plug to make the jumper Yes, I do have. I tend to keep my old parts, don't know why. That's a great idea. I'll check and keep you posted. 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 (edited) 5 minutes ago, Dat521sun said: Autozone. My old carb was weird, it was manual choke, but without the cord. The PO owner vent the throttle cable so truck always idle high, I had to pull the accelerator pedal with my toes. I replaced the carb, and it was electric, a few months after that, first alternator died. 2 weeks ago, I replaced the carb with a manual choke Well autozone has something wrong where you are or they didnt listen to what vehicle you told them.... I just pulled that listing up from autozone.... Any how... you may still have that choke relay in there which will cause a power drain.... if you dont need it just unplug it... Edited December 27, 2019 by Crashtd420 1 Quote Link to comment
datzenmike Posted December 27, 2019 Report Share Posted December 27, 2019 '72 was the first electric choke I believe. Internally regulated have an L and S marked terminal plug. External are marked F and N. I would say that the one in the picture is an internally regulated alternator. The 521 should have a removable black plastic cover on the back 2 Quote Link to comment
datzenmike Posted December 27, 2019 Report Share Posted December 27, 2019 You can remove the external regulator and join two pair of wires to convert your harness to use an internally regulated alternator. 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 Cutted old plug from bad VR and made the jumper, connected white/red wire with white/black and solid white with solid yellow. 2 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 (edited) Ign light won't come on with jumper when key is turned and I still get 11.70 volts at battery when truck is at idle Edited December 27, 2019 by Dat521sun 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 3 minutes ago, Dat521sun said: Ign light won't come on with jumper when key is turned and I still get 11.70 volts at battery when truck is at idle Unplug the alternator t plug and see if you have power on the yellow wire..... 1 Quote Link to comment
datzenmike Posted December 27, 2019 Report Share Posted December 27, 2019 Ignition light must be working. It goes to ground through a diode and lights when ignition in the on position. Once running and charging there is 12 v on both ends and the light goes out. There's a good chance the alternator was bad to begin with. That's the junk they sell today. 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 You could ground the white and black and see if the light comes on to verify... unplug t plug first.... 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 6 minutes ago, Crashtd420 said: Unplug the alternator t plug and see if you have power on the yellow wire..... I'm getting 11.25 volts at yellow wire with t plug disconnected 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 (edited) That's a bit low for a resting battery... Even a dead battery that can be charged would rest at 12.5..... Do you have power on the other wire, white/black? Test with ignition on... if you have power there, ground the wire and see if the light comes on.... Edited December 27, 2019 by Crashtd420 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 I'm getting over 16 volts at alternator 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 2 minutes ago, Crashtd420 said: That's a bit low for a resting battery... Even a dead battery that can be charged would rest at 12.5..... Do you have power on the other wire, white/black? Test with ignition on... if you have power there, ground the wire and see if the light comes on.... With t plug disconnected I have no power at the white/black stripe 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 (edited) 16v ???? How.... with the t unplugged and running? Edited December 27, 2019 by Crashtd420 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 1 minute ago, Dat521sun said: With t plug disconnected I have no power at the white/black stripe Check the connector then.... or even try checking for power where you plugged in the jumper.... might be a bad connection there.... 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 3 minutes ago, Crashtd420 said: ???? How.... with the t unplugged and running? If I connect t plug, I do have power at white/black stripe wire 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 3 minutes ago, Crashtd420 said: Check the connector then.... or even try checking for power where you plugged in the jumper.... might be a bad connection there.... I have power in connections. Light is brighter at white/black stripe 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 Well when plugged in the alternator is outputting 12v. Thought the white/black to turn off the light.... if unplugged and no power you have a burnt fuse or bulb. ... 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 8 minutes ago, Crashtd420 said: Well when plugged in the alternator is outputting 12v. Thought the white/black to turn off the light.... if unplugged and no power you have a burnt fuse or bulb. ... I meant the testing light is brighter. I'm getting over 16 volts at white/black stripe 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 Now truck keeps running when key is turned off 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 (edited) 10 minutes ago, Dat521sun said: I meant the testing light is brighter. I'm getting over 16 volts at white/black stripe Well that shouldn't be...... Edited December 27, 2019 by Crashtd420 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 Just now, Dat521sun said: Now truck keeps running when key is turned off Your back feeding power to the ignition circuit..... 1 Quote Link to comment
Dat521sun Posted December 27, 2019 Author Report Share Posted December 27, 2019 1 minute ago, Crashtd420 said: Your back feeding power to the ignition circuit..... Disconnected jumper, turned key off and truck turned off 1 Quote Link to comment
Crashtd420 Posted December 27, 2019 Report Share Posted December 27, 2019 1 minute ago, Dat521sun said: Disconnected jumper, turned key off and truck turned off Ok I think I know what happened.... 1 Quote Link to comment
