fwo Posted December 11, 2019 Report Share Posted December 11, 2019 My neighbor/mechanic and I pulled the fuel tank and did conclude that it is no good anymore. I've had had a tough time, as to be expected, finding any tanks online and am wondering if any of you have any suggestions on aftermarket fuel tanks that would work for my '76? Ideally minimal fabrication required if possible. Thanks! Quote Link to comment
bilzbobaggins Posted December 12, 2019 Report Share Posted December 12, 2019 What exactly is wrong with it? Your old tank that is. Quote Link to comment
datzenmike Posted December 12, 2019 Report Share Posted December 12, 2019 There are two part epoxy mixes that are poured into the tank, then roll around to evenly coat and seal them. They ain't cheap but they work quite well. Way cheaper than a new one..... if they can be found. 1 Quote Link to comment
fwo Posted December 12, 2019 Author Report Share Posted December 12, 2019 13 hours ago, bilzbobaggins said: What exactly is wrong with it? Your old tank that is. Tank is full of rust. Quote Link to comment
fwo Posted December 12, 2019 Author Report Share Posted December 12, 2019 11 hours ago, datzenmike said: There are two part epoxy mixes that are poured into the tank, then roll around to evenly coat and seal them. They ain't cheap but they work quite well. Way cheaper than a new one..... if they can be found. Thanks, I'll look into those also. Quote Link to comment
Crashtd420 Posted December 12, 2019 Report Share Posted December 12, 2019 If you dont wanna go through all the effort but dont mind paying some money... check out radiator shops or google gas tank cleaning.... I found a local shop to me that cleaned it out, replaced my pickup tube, and sealed the inside.... I opted not to have then paint the exterior ... I think I paid around 250 - 300 to have that done.... 2 things definitely make sure your pick up tube is good.... they do get clogged with rust.... Also with those diy epoxys and tank coating kits the biggest thing you need to do is follow the prep work they say.... If the prep work is not good the product can and will peel off the inside.... 1 Quote Link to comment
bilzbobaggins Posted December 12, 2019 Report Share Posted December 12, 2019 2 hours ago, fwo said: Tank is full of rust. Long as it aint rusted thru it should be able to be saved. 2 Quote Link to comment
fwo Posted December 16, 2019 Author Report Share Posted December 16, 2019 On 12/12/2019 at 9:57 AM, Crashtd420 said: If you dont wanna go through all the effort but dont mind paying some money... check out radiator shops or google gas tank cleaning.... I found a local shop to me that cleaned it out, replaced my pickup tube, and sealed the inside.... I opted not to have then paint the exterior ... I think I paid around 250 - 300 to have that done.... 2 things definitely make sure your pick up tube is good.... they do get clogged with rust.... Also with those diy epoxys and tank coating kits the biggest thing you need to do is follow the prep work they say.... If the prep work is not good the product can and will peel off the inside.... Great idea, thanks! Quote Link to comment
