G8KeaPoR Posted October 21, 2019 Report Share Posted October 21, 2019 So I’m yanking the Weber’s to give them a full disassembly and figured I’d do a port job on the head and clearance the valves. And while I am at it I will stick the intake manifold on the CNC mill so o can make a real vacuum port that spans all 4 cylinders for the vac advance. Going to see if it helps the below 40’s cold start and idle. Worst case I tap and plug the holes.. sorry off track a bit. Anyway I wasn’t sure what you all recommend for headgaskets manifold gaskets etc. I was finding. A ton of felpro which I abhor so I was thinking of going o Nissan since they still have them but would like stronger options if available. Let me know. Quote Link to comment
datzenmike Posted October 21, 2019 Report Share Posted October 21, 2019 No engine since the mid to late '60 runs intake manifold vacuum, they are all ported from the carburetor. Your distributor is not set up for that and will run too advanced... if you back the timing off to stop pinging it will be too retarded at full mechanical advance. Better to simply leave it alone. There's nothing wrong with felpro head gaskets on an L20B. There's no special requirement for the manifold gasket either. NAPA has them. 1 Quote Link to comment
banzai510(hainz) Posted October 21, 2019 Report Share Posted October 21, 2019 (edited) I would go Nissan head gasket or Durapro graphite out of Australia which is really a a Japan made gasket in 87mm cold start/ Use the choke and no gas Or no choke and pump the gas most L motor running carb just adv the dist to like 12-15 intial advance Edited October 21, 2019 by banzai510(hainz) 2 Quote Link to comment
G8KeaPoR Posted October 27, 2019 Author Report Share Posted October 27, 2019 (edited) On 10/20/2019 at 10:10 PM, datzenmike said: No engine since the mid to late '60 runs intake manifold vacuum, they are all ported from the carburetor. Your distributor is not set up for that and will run too advanced... if you back the timing off to stop pinging it will be too retarded at full mechanical advance. Better to simply leave it alone. There's nothing wrong with felpro head gaskets on an L20B. There's no special requirement for the manifold gasket either. NAPA has them. C,outdoor I just drill the backside of the carb? DCOE 9’s and 13’s had vacuum ports for a vacuum advance on equippped MG’s. Assuming that all they did was cast block it off the pathway should still be there. Worst case I can just plug iTunes back up. Other option is to use a. Vacuum pill like they used from the factory on my 3rd gen RX 7 after the balance tube to limit the vacuum pull after to a maximum based on diameter? I live in the sticks so the added mileage benefit would be nice. I’ll probably cross that bridge of to try or not after I get it disassembled for the rebuild. It may just be more trouble than it’s worth.... which it sounds like. EDIT - I have no idea why auto correct inserted iTunes back up. Guess I will chalk it up to it just being a crapple thing. Edited October 28, 2019 by G8KeaPoR Quote Link to comment
G8KeaPoR Posted October 28, 2019 Author Report Share Posted October 28, 2019 On 10/21/2019 at 9:26 AM, banzai510(hainz) said: I would go Nissan head gasket or Durapro graphite out of Australia which is really a a Japan made gasket in 87mm cold start/ Use the choke and no gas Or no choke and pump the gas most L motor running carb just adv the dist to like 12-15 intial advance Got a part number and know a Nissan dealer or place that sells the Factory Nissan parts? I won’t use the dealer near me after they lied on the options on the Nissan Rogue that I traded in after 5 months.. honestly blessing in disguise aside from the faulty fan blower motors the car sucked. Quote Link to comment
banzai510(hainz) Posted October 28, 2019 Report Share Posted October 28, 2019 as DatzenMike I had lost my part number book. I got about 4 head gaskets and that should last me a lifetime . Quote Link to comment
