Cardinal Grammeter Posted June 14, 2019 Report Share Posted June 14, 2019 (edited) Need today for tomorrow (Saturday) appointment. I want to get the layout and ribbing correct. Thanks Tom EDIT: After almost 2 hours found a 1980 620 that was sold or 115,000 Baht https://www.one2car.com/en/for-sale/datsun-620-single-bangkok-metropolitan-pinklao-borommaratchachonnani-road/2169393 This looks like the late model rib and wire layout but w/o the cutaway. The parts manual actually shows ribs and wire configuration - the early had almost a bucket seat rib layout: 2 pair of rib groups and 4 wires (2 per "bucket") including on the seat cushion. I really want to find a pic of that layout. (But it's probably not a good idea to put a wire in the seat cushion from a durability perspective. The Thai version in tweed w/vinyl ends I suppose. Edited June 15, 2019 by Cardinal Grammeter Quote Link to comment
frank88 Posted June 15, 2019 Report Share Posted June 15, 2019 (edited) This is mine. Fairly sure it's an original seat (not to my truck) Edited June 15, 2019 by frank88 1 Quote Link to comment
Cardinal Grammeter Posted June 15, 2019 Author Report Share Posted June 15, 2019 (edited) Thanks Frank! I suspect the bottom has been replaced: *) The back has 3 groups of ribs which do not line up with the 2 groups on the bottom *) The bottom is usually more worn than the back. But even if the back suffering from sun damage, it's hard to imagine the bottom not having any rips. Given the awful condition of the back, I suspect the bottom was so much worse it had to be redone. *) There is a color difference. But the back coincides with the nice Indo black pic I came up with and NOT the pattern in the parts manual. I'm getting pumped at the thought of a "new" seat! Tom Edited June 15, 2019 by Cardinal Grammeter 1 Quote Link to comment
frank88 Posted June 16, 2019 Report Share Posted June 16, 2019 Very good points. Be sure to post a pic when its done. Mine currently has a tie dye sheet thrown over it! 1 Quote Link to comment
620slodat Posted June 17, 2019 Report Share Posted June 17, 2019 (edited) I have a 1973 620 that was my dad's, which he bought brand new. I know the full history on it, and the straight front seat is the original in it. If I can figure out how to post it I have a pic of the drivers side of the seat. I am surprised in how good of condition it is considering the age. Dad put some foam rubber and an aftermarket seat cover on it. Although I only pulled the foam and seat cover off the drivers side to get pics and to look at it, the drivers side usually gets most of the wear. There is one rip in it, in the sewn section, the full length of the rib, and the foam under the original seat cover is in good shape. I will try now to see if I can post a pic. Don ps-the seat shown in the first post could be the same as the one I have. Edited June 17, 2019 by 620slodat 1 Quote Link to comment
620slodat Posted June 17, 2019 Report Share Posted June 17, 2019 I definitely am technically challenged. My daughter was able to get the pic here, but I don't understand how she got it here. Anyway, here is the drivers side of the seat. The pickup is under construction so the other side of the seat (and elsewhere) is covered with parts. It appears to be the same configuration as in the first post. I hope this picture helps you. Don 1 Quote Link to comment
Cardinal Grammeter Posted June 22, 2019 Author Report Share Posted June 22, 2019 I'm a bit irritated by another shop I went to. On the phone, I say use whatever black material you have on hand, etc. to keep costs down since work truck - quotes roughly $200-220, maybe $250 if it needs spring work. Then I get there and it's $350, can get any material I want, frame and springs will be painted, etc. and "I have to do a fine job because of my reputation." Although this guy will probably do the best job, I really don't want to do business with him - if he would have said $350, I'd have never drove the truck to him to look at and stuck with the 1st outfit that quoted $375 looking at the truck. So now I'm thinking this Trex duct tape has better adhesive than Gorilla Tape.... @#(*&*#($ 1 Quote Link to comment
