Lonewolf1990 Posted April 14, 2019 Report Share Posted April 14, 2019 Alright so who has done adjustable coilovers for the front for a 620 , this is a sure that I wanna do next Quote Link to comment
datzenmike Posted April 15, 2019 Report Share Posted April 15, 2019 What spring rate? You said the ride was bumpy? How are you shock absorbers? Quote Link to comment
Lonewolf1990 Posted April 15, 2019 Author Report Share Posted April 15, 2019 27 minutes ago, datzenmike said: What spring rate? You said the ride was bumpy? How are your shock absorbers? Not to sure , ooo they are shit Quote Link to comment
datzenmike Posted April 15, 2019 Report Share Posted April 15, 2019 Worn shocks give a very harsh ride on any vehicle. Without them a spring absorbs all the bump energy and releases it back to the tire which rebounds the energy back to the spring and this can happen several times till it dampens out. Worst, a tire ca even lift off the ground which is not good in a turn. Jump in the bed, try to get it bouncing. Stop suddenly. If the truck continues more than 1/2 a bounce they could be replaced. Are any leaking or wet? Remove and see if you can open and close them easily. Some will collapse freely for several inches before there is resistance. Quote Link to comment
5t341tH Posted April 17, 2019 Report Share Posted April 17, 2019 (edited) how much do you want to spend? lots of people are using the qa1 coilovers. expect to spend around 800 for just the fronts Edited April 17, 2019 by 5t341tH Quote Link to comment
Lonewolf1990 Posted April 17, 2019 Author Report Share Posted April 17, 2019 48 minutes ago, 5t341tH said: how much do you want to spend? lots of people are using the qa1 coilovers. expect to spend around 800 for just the fronts Right now I found a pair of coilover shocks for the front , now just to find the springs that will be a good fit for the truck Quote Link to comment
