Datsunny Posted November 15, 2008 Report Share Posted November 15, 2008 hey guys trying to do a l16 swap in my 520 any pointers ? Quote Link to comment
datzenmike Posted November 15, 2008 Report Share Posted November 15, 2008 I assume it has a J motor now and you're putting the L into it? Quote Link to comment
jefe de jefes Posted November 15, 2008 Report Share Posted November 15, 2008 (edited) Weld up some new motor mounts. Edited November 15, 2008 by jefe de jefes Quote Link to comment
sycloned916 Posted November 15, 2008 Report Share Posted November 15, 2008 I'm doing the same swap L16w/5speed in my 1967 520.I'll be doing the swap in afew weeks here,kinda knew i was going to have to do some welding,the J13 mounts look different from what i have,the position of the L series mounts,but a welder and a cut-off saw should fix that. Quote Link to comment
Datsunny Posted November 15, 2008 Author Report Share Posted November 15, 2008 ok well we took the old motor mounts out and got ones out of the donor truck the ones on the j motor mount facing the front and the L mounts face the outside sides i am going to bolt up the stock 4 speed to the L motor for the sake of having a bench seat but i am changing out 4 gear to make it longer so it can travel on the freeway Quote Link to comment
yellowdatsun Posted November 15, 2008 Report Share Posted November 15, 2008 I'd be curious to see how much room you have left. The 520 engine bay is a few inches shorter than the 521. Do you have room enough for the radiator/fan? Quote Link to comment
sycloned916 Posted November 15, 2008 Report Share Posted November 15, 2008 I'd be curious to see how much room you have left. The 520 engine bay is a few inches shorter than the 521. Do you have room enough for the radiator/fan? I should have enough room for the radiator and fan, If not i can put a fan on the front or find a slim ele. fan. Quote Link to comment
Datsunny Posted November 16, 2008 Author Report Share Posted November 16, 2008 i am using a radiator out of an 89 civic and mounting the electric fans on the front Quote Link to comment
Cuts metal like mad Posted November 16, 2008 Report Share Posted November 16, 2008 On the 520 and j13 521, there is a "box" that the radiator bolts to(it's spot welded on) if you remove it, you can bolt the L16 radiator right in, the holes are already there! One thing that seems strange to me though is how HUGE the steering idler box is, it's not just an arm like L powered trucks it's a big box... Quote Link to comment
Datsunny Posted November 17, 2008 Author Report Share Posted November 17, 2008 yeah it is i am taking pics to post them on here there are a few things i have questions about Quote Link to comment
datsunaholic Posted November 17, 2008 Report Share Posted November 17, 2008 I'm interested on how you intend to "change out" 4th gear, since all 4-speeds use a 1:1 (direct drive) 4th gear. Quote Link to comment
Datsunny Posted November 17, 2008 Author Report Share Posted November 17, 2008 and these are the things i need to learn about hahahahhahah Quote Link to comment
Craig Hughes Posted December 5, 2008 Report Share Posted December 5, 2008 Sounds like a great prodject and your going to have a hunk of old J13 laying around, will you be looking to sell?:confused: Quote Link to comment
