Shaun Posted January 13, 2019 Report Share Posted January 13, 2019 I have a 1985 Nissan 720 2.4l 2wd the carb has a 6 wire plug on it.i have another carb just like it but has a 2 wire plug on it.are the y interchangeable with a little splicing 1 Quote Link to comment
]2eDeYe Posted January 13, 2019 Report Share Posted January 13, 2019 Best bet is to find a wiring diagram for both carbs and then it will be pretty easy to adapt. 1 Quote Link to comment
MaxChlan Posted January 13, 2019 Report Share Posted January 13, 2019 (edited) Here's the wiring diagram for the stock Hitachi carburetor: From what I've read about swapping carbs, the only one you need is the choke wire. Edited January 13, 2019 by MaxChlan 1 1 Quote Link to comment
datzenmike Posted January 13, 2019 Report Share Posted January 13, 2019 The above is the electronic feedback carburetor. It's half way to being EFI/carburetor. It has a variable primary jet solenoid that flutters open and closed to let gas through. This is controlled by a computer to set the air fuel ratio with feedback from a closed loop O2 sensor. I'm not sure if the mounting bolt pattern is the same as a regular carb but if it is all you need is connect the Red idle cut and the Blue (marked L in the diagram) choke heater wires. 1 Quote Link to comment
Shaun Posted January 15, 2019 Author Report Share Posted January 15, 2019 Thanks for the help and diagram on the diagram it has a red and black wire on antideseling solenoid and on my other carb it just has a red wire on it. Not really sure how to splice that in. Other than that I’m good to go 1 Quote Link to comment
Scoutsun Posted April 25, 2021 Report Share Posted April 25, 2021 On 1/13/2019 at 10:55 AM, MaxChlan said: Here's the wiring diagram for the stock Hitachi carburetor: From what I've read about swapping carbs, the only one you need is the choke wire. I have the same carb, where can I get the full service manual or diagrams like this for it? 1 Quote Link to comment
datzenmike Posted April 25, 2021 Report Share Posted April 25, 2021 Factory service manual? e-bay probably. 1 1 Quote Link to comment
