724xz Posted January 8, 2019 Report Share Posted January 8, 2019 Alright got a 85 720 2.4z blew head gasket between 3 & 4 replaced it along with the pesky tensioner deal got everything back together and adjusted valves cranked and there is a constant tapping noise coming from the same area. also before start I went through the bottom end main bearing caps before accepting the headgasket failure, any ideas, valve sticking, piston failure from cam timing? Sounds about the same as when it blew less the miss. 1 Quote Link to comment
datzenmike Posted January 8, 2019 Report Share Posted January 8, 2019 From what you say, it sounds like it was tapping before you blew the headgasket? Yes? Unlikely a piston or you would have seen damage when changing the gasket. Main bearings rarely go bad as they get oil first before feeding the rods. All the mains do is turn and there's 5 of them to share the load. Rods are all alone taking the pounding from the piston. Knock? A lower frequency like a 4 pound sledge hammering on the block? Does it get louder if you step on the gas briefly? Yes.... Rod bearing. Taps are higher pitch and metallic. Ticking. Has to be in the top end. Valve lash is 0.012" on both. Set on a hot not cold engine. 1 Quote Link to comment
DIY 1985 Posted January 8, 2019 Report Share Posted January 8, 2019 But it doesn't sound like a ball bearing hitting the bottom of a paint can? 1 Quote Link to comment
Stoffregen Motorsports Posted January 8, 2019 Report Share Posted January 8, 2019 Does it run better since you replaced the head gasket? I have seen erosion in the aluminum between combustion chambers. This can cause a "tap" almost like an exhaust leak. Are you sure you don't have an exhaust leak? Like a cracked manifold? That can sound like a tap. 1 Quote Link to comment
datzenmike Posted January 9, 2019 Report Share Posted January 9, 2019 Again it would get louder under load. 1 Quote Link to comment
