Fetch Posted November 7, 2018 Report Share Posted November 7, 2018 (edited) I thought I would start new with the roadster build using postimage. I lost a lot of pictures with pbucket and upgrading my computer. My original build is here but without pictures. I am sure I will be editing this post. https://ratsun.net/topic/64942-new-to-the-forum-not-to-datsuns/ Here are a couple of pictures of the 1500 rebuild, which has been the biggest expense so far. The new rocker assembly is from Datsunparts.com. Bottom end is ready. I have the water pump, oil filter mount, fuel pump and timing gears ready to go on. Need a few misc parts for the carbs and dizzy Getting the pictures sorted. Edited November 7, 2018 by Fetch 3 Quote Link to comment
]2eDeYe Posted November 11, 2018 Report Share Posted November 11, 2018 Looks like a good start ? Quote Link to comment
Fetch Posted November 12, 2018 Author Report Share Posted November 12, 2018 (edited) I found my thumb drive with some early pictures. Brakes are rebuilt, gas tank has been cleaned, sealed and installed. Carbs are rebuilt.I gutted the seat to get rid of the petrified mouse and had to make a new latch pin. The seat is actually quite comfortable. Edited November 12, 2018 by Fetch 1 Quote Link to comment
bing_kee66 Posted November 13, 2018 Report Share Posted November 13, 2018 i like the upholstery Quote Link to comment
Fetch Posted November 18, 2018 Author Report Share Posted November 18, 2018 (edited) When it is too cold to work in my garage, I work on my mead. This batch is a dark cherry is about 15% and on the dry side. I have about 9 gallons in various fermentation stages. This batch is one year old and very smooth. Edited November 18, 2018 by Fetch 2 1 Quote Link to comment
Fetch Posted November 22, 2018 Author Report Share Posted November 22, 2018 (edited) Got home early from work, not to cold out so I pulled the heater. So easy. Two nuts on the firewall. A bit of stuff in the hose. Fortunately no critters in the housing. The heater core shows no sign of leaking. Although the flow control valve is stuck. The hot air ducts do need some attention. Found beach sand in them. Edited November 22, 2018 by Fetch Quote Link to comment
dukerollo Posted November 22, 2018 Report Share Posted November 22, 2018 (edited) It looks like you have made a good start. I keep seeing these pop up cheap and am always tempted. I already have enough problems though.... Edited November 24, 2018 by dukerollo 1 Quote Link to comment
Fetch Posted November 22, 2018 Author Report Share Posted November 22, 2018 (edited) Duke, I got this one really cheap with the expectation I would be putting some money into it. Parts are less available and there are just not that many cars left. I found a '70 for $3000 but right off I would be putting $2000 into body work. As for the heater, I got the control valve out, just need to get a O-ring and the core cleaned. Fan works at the different speeds. Edited November 22, 2018 by Fetch Quote Link to comment
Fetch Posted December 3, 2018 Author Report Share Posted December 3, 2018 (edited) Not much going on, lows around 25, highs about 35, which is the temp in my garage. I did pop open the transmission, looks new hardly any wear on the gears. Who ever drove it know how to shift. Back up light switch was stuck, fixed it works fine. Here is the old and new old clutch. I think is it a truck disk and about 30 years old, never used. If anyone has a 10 spline tool I can borrow, let me know. Edited December 3, 2018 by Fetch Quote Link to comment
Fetch Posted January 12, 2019 Author Report Share Posted January 12, 2019 Got the starter checked, ok. I have two pos ground alt, rebuilt the best one, 300w of power. Ordered other parts, waiting for parts. Quote Link to comment
Fetch Posted January 19, 2019 Author Report Share Posted January 19, 2019 I got some parts in for my clutch, carbs and dizzy. I was looking for something to hold the dizzy while I re-rebuilt it. Saw my crank pulley on the bench and stuck the dizzy in. Fit like a glove. Fascinating. Quote Link to comment
Fetch Posted April 6, 2019 Author Report Share Posted April 6, 2019 Been a while, Engine, trans ready to go in. Brake, clutch mc are in. Need to bleed the brakes. Wiring is 90% complete. Dash is back together. Tail lights are on. Got wheels powder coated, new tires. Cosmetics, not so good yet. Rolled it out of the garage so I can clean said garage. Did I write it has been four years since it has had the wheels on? 2 Quote Link to comment
Fetch Posted August 10, 2019 Author Report Share Posted August 10, 2019 (edited) Been working on my house, building a deck, all the things to keep me from working on the car. But I have made some progress. Fixed more wiring, etc. Fitted the radiator, Yes, I had to get into the regulator, didn't touch the innards,cleaned wires, made a new wire, looks good and put it back, Fixed the exhaust manifold and cleaned up the ports. Edited August 10, 2019 by Fetch 2 Quote Link to comment
