86720 ST Posted September 20, 2018 Report Posted September 20, 2018 I have a 85 ST with manual windows, and I have some door with power windows. Will my truck with the manual windows have the wiring for the power window doors? 1 Quote
Madkaw Posted September 20, 2018 Report Posted September 20, 2018 From what I’ve read , power windows have to stay in doors that came with power windows. No provision for power windows on manual doors 1 Quote
datzenmike Posted September 21, 2018 Report Posted September 21, 2018 The inner door skins are too different between roll up and electrical.Much easier to swap doors which are all the same IIRC. The wiring will not be in your truck so if you find an electric window get the wiring or wire it up yourself. Everything will be on the door all you need is a power supply. Make sure it is fused. 1 Quote
Charlie69 Posted September 21, 2018 Report Posted September 21, 2018 No the wiring harness from the truck with the power doors is needed also. I am up grading my 86 720 2wd King Cab to power doors and have harvested the the power door harnesses also. Quote
86720 ST Posted September 21, 2018 Author Report Posted September 21, 2018 Do I need the complete harness from under the dash? I have the harness coming from the doors when I took them off of my old truck. 1 Quote
datzenmike Posted September 21, 2018 Report Posted September 21, 2018 My FSM barely mentioned this option and it isn't in the wiring diagram either. If you have the wires from the door you should be able to cobble something together to make it work. I put second gen 200sx electric windows in my 620. I used 70s GM electric door switches. 1 Quote
Charlie69 Posted September 23, 2018 Report Posted September 23, 2018 I get the complete dash and engine compartment harness and will be changing the complete harness when I install the electric doors. I have not been able to find a factory wiring diagram on the electric doors. Quote
