Beastlikethat1 Posted July 30, 2018 Report Share Posted July 30, 2018 So I have a U20 intake and SU carbs, actually in beautiful shape and I was given a R16 engine in great shape. I can obviously see that this U20 intake doesn't match up with the R16 head ports. Will these carbs work with a R16 intake; to where I could just buy proper intake? Or should I just try to sell/ trade these for carbs that will fit? Thanks guys! Quote Link to comment
MikeRL411 Posted July 30, 2018 Report Share Posted July 30, 2018 An absolutely beautiful set of U20 carbs ! If it were mine [jealousy apparent] I would prefer to trade an authentic U20 set for an RL411 or 311 roadster set including the manifold. Why ? for authenticity's sake ! Depending on the target vehicle, which you neglected to specify, the replacement set of carbs may well need to be with the intake gasolene tubing either both on the front ALA RL411 sedan or with front and rear tubing alternating ALA PL311 roadster. Details do count ! Quote Link to comment
Beastlikethat1 Posted July 30, 2018 Author Report Share Posted July 30, 2018 Sorry about that! It's a 1967 Roadster 1600 that originally came with the R16 and 4spd. The car was stripped though a long time ago and then barn kept for years. I recently bought it for cheap but as I said it's just a roller, was lucky and had a friend give me some stuff to help get it going again Quote Link to comment
hosestop@msn.com Posted July 30, 2018 Report Share Posted July 30, 2018 Have a manifold with a small crack can be welded. Quote Link to comment
datzenmike Posted July 30, 2018 Report Share Posted July 30, 2018 I should imagine they are 40mm and the R16 needs 38mm. Sort of like running 240Z 46mm? carbs on a much smaller L20B. Not saying it doesn't work but moving more air will probably need the needles and seats changed? Quote Link to comment
Beastlikethat1 Posted July 30, 2018 Author Report Share Posted July 30, 2018 1 hour ago, hosestop@msn.com said: Have a manifold with a small crack can be welded. R16 manifold? Where I work we weld aluminum. How much would you want for it? Quote Link to comment
