David lo pan 2 Posted June 30, 2018 Report Share Posted June 30, 2018 so did the swap. numbered out the neutral switch. starts fine. but when I hook up the the red/black wires to reverse switch nothing happens. does not start and the reverse lights don't come on either. I checked continuity on the switch, checked bulbs all are good. weird thing is after I disconnect the red/black reverse wires and wait awhile the car starts again without the red/black. also blue/black wires? can figure out where they go to. oh 1973 610 sedan. thanks guys 1 Quote Link to comment
datzenmike Posted June 30, 2018 Report Share Posted June 30, 2018 Traditionally Red/Black wires are the reverse lights switch. Polarity is not important. On a 71B transmission, connect switch, located just behind the clutch arm dust boot, to the harness. The Neutral Park safety switch, just join the other two wires together and the ignition is the switch. The automatic has a separate switch to open and prevent the ignition from starting in any position other than Park or neutral. On a 710 the two wires are Green and Black/Green... don't know what thew 610 would be. 1 Quote Link to comment
David lo pan 2 Posted June 30, 2018 Author Report Share Posted June 30, 2018 thanks Mike, I'll fiddle-fk with it. 1 Quote Link to comment
MikeRL411 Posted June 30, 2018 Report Share Posted June 30, 2018 Yourst for the record, it might have helped if you specified just which of your vehicles this plea was addressed for !!!!!!!!!!!!!!!!! Quote Link to comment
KELMO Posted June 30, 2018 Report Share Posted June 30, 2018 He did, "oh, 1973 610 sedan" in the first post. B) EDIT: oops, didn't notice any edit. Quote Link to comment
datzenmike Posted June 30, 2018 Report Share Posted June 30, 2018 Was here at 11:48 and may have added it after Mike's 11:42 post. I assumed it was a 610 because of the fuse box cover... Quote Link to comment
