Carb gasket leaking
Dirtyowlnumber4
My car is screaming like a banshee and revving really high but it will go back to norm if I push the carb fwd and hold it there. Seems like it's drawing air in through the gasket, but the bolts are as tight as I can get them.
I was wondering if it would be all right to put red rtv or something on it.
  • Replies 15
Sounds like vacuum leak. Stock carb or Webber carb. While car is running on idle, Spray carb cleaner around base and area and listen carefully. If rpm goes up, then vacuum leak. Don't gorilla tight the hold down bolts. Base can get warped, then you will have to get a new one.
It is a Weber, yeah I tightened one of the bolts and it stopped for a second, then I tightened another one and it started again and I couldn't fix it again. I'll spray some cleaner on it.
In order to rev up it needs gas AND air. Air alone from a leaking gasket won't do it.
Is this with the engine fully warmed up??? Is the choke on?
It seemed like it started happening once it got warm I haven't had much time too look at it though. Choke isn't hooked up.
If I push down on the air filter the whistling stops and it revs down to 800rpm, otherwise it's up at like 1500 and whistling like a bitch. All the bolts are tight I dunno
K I sprayed carb cleaner around the gaskets it seems like it's leaking where that carb meets the adapter I'll pop it of and have a look they sent me like 3 gaskets so i could try another one
Check the adaptor for flatness too while you have it off....
