85 720 kc electrical bracket on battery terminal broke
  • Replies 10
That's the connection for the three fusible links. You'll have to make something or get from another 720*. This is likely the best bet
Nissan dealer may have something but...
Looks like you have an '85 so...
#24022-10W00 if Z24 engine
#24022-80W01 if you have the Z24i engine
This is for the fusible links (both about $25) but it's unclear if it includes that terminal or not.
Is the mounting lug on the black piece still attached to it? Basically I'm asking uf the battery side of the terminal broke or if the plug side of it broke.
I've used many universal battery terminals with minor modifications to mount the fusible link block to.
Your pic doesn't work. Don't use photobucket. They no longer function.
Battery side broke Lockleaf.
I would try tack welding it back together myself, next I would look in the wrecking yards.
Probably brass. Not sure you can just weld brass. Solder is not a good mechanical connection either.
