Sign in to follow this
A_Racing_Driver
300ZX Auto whining noises
So I recently got a 1984 300ZX Turbo but its auto and Im having some trouble, theres a whining noise when its cold i suspect from the transmission or diff not sure which yet it doesnt make it when in park and it doesnt increase with speed but it gets louder with higher rpm what do you think it is? My guess is something with transmission.
Share this post
Link to post
Probably right about that. Does it go we away when you press the clutch?
Could be input shaft bearing
Share this post
Link to post
What color is the fluid on the stick? It should be bright ruby red and see through. If cloudy and dull or any appearance of being burnt have it replaced. See below
Whiny noise with automatics when cold is usually cavitation. The fluid is thicker when cold and the filter inside is dirty and restrictive. The hydraulic pump can't pull the fluid if fast enough and a vacuum forms behind the impellers. Usually a filter and fluid change reduces this.
Share this post
Link to post
 When did they put in a clutch pedal for an automatic?  :angel:
My reading comprehension levels need work.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
