Cary Posted June 19, 2017 Report Share Posted June 19, 2017 The wiring on this on truck has been hacked on over the years. On the bottom of the dizzy is a single spade plug and coming from the are on the fender where the coils are, I have a small harness with a black plug and a white plug, both of which will take a single spade. Any idea which goes to the dist? Quote Link to comment
datzenmike Posted June 21, 2017 Report Share Posted June 21, 2017 That's a CAS crank angle sensor so... dunnow. Quote Link to comment
LenRobertson Posted June 21, 2017 Report Share Posted June 21, 2017 The only thing in my collection close to your Z24 is a dizzy from an '81 Z20e with eight plug head. If I can find it tomorrow I'll take a look at it. The '79 "matchbox" dizzys I'm more familiar with have two male spade terminals on top of the black matchbox on the side of the dist. body. These two go to the plus and minus on the coil. I think they are even marked + and - on the matchbox. Some of this style dist. have a male spade below the matchbox that is for a ground wire. But I have a feeling your '88 is enough different that none of this applies to your unit. Maybe you will get a response from someone who actually knows Z24s. Len Quote Link to comment
distributorguy Posted June 21, 2017 Report Share Posted June 21, 2017 It should just have a 2-wire plug that goes into a separate amplifier box, or its not a stock distributor. 1-wire would indicate points, so it wires to the negative side of the coil. Any electronic distributor will be 2-wire. Quote Link to comment
Cary Posted June 22, 2017 Author Report Share Posted June 22, 2017 I will snap a pic in the morning. It is a standard z24. The one group of wrapped wires comes off the distributor but there is the single spade right next to the normal wires. Quote Link to comment
LenRobertson Posted June 22, 2017 Report Share Posted June 22, 2017 You posted your pics as I was typing a reply. I'm going to go ahead and post what I typed. Your dist looks very much like the ones on eBay but maybe the connectors are different on yours. Does your dizzy look anything like this one? http://www.ebay.com/itm/Reman-A-1-Cardone-Distributor-Electronic-fits-1986-1988-Nissan-D21-Pathfinder-/112325971900?fits=Make%3ANissan%7CModel%3A720&hash=item1a27264fbc:g:UDoAAOSwWxNYvZMc&vxp=mtr It seems to have 4 male spade connections recessed into the lower side of the body. Pics of a similar unit on eBay showed a short wire plugged into this recess with 4 spades on the connector at the other end of the wire. http://www.ebay.com/itm/Distributor-New-for-Nissan-Pathfinder-D21-Hardbody-720-Truck-1985-NS31-/122420067995?hash=item1c80cdfe9b:g:gjgAAOSwuxFY20gi&vxp=mtr But what this wire plugs into, I have no idea. As datzenmike said this is a crankshaft position sensor type unit so I don't know if it uses a regular coil or some sort of coil pack. Len Quote Link to comment
datzenmike Posted June 22, 2017 Report Share Posted June 22, 2017 I think the CAS tells the computer where the crank is and IT decides when to tell the coil to fire. It's only connection to the coil is that it has a rotor on top to send the spark to the cap and wires. Quote Link to comment
distributorguy Posted June 22, 2017 Report Share Posted June 22, 2017 Ohm that terminal and check to see if it isn't just a ground. Most Hitachi distributors have a single spade for grounding. Quote Link to comment
