d.p Posted May 18, 2017 Report Share Posted May 18, 2017 One between carb and the intake manifold, mine shit the bed and my fel pro gasket kit did not come up with a replacement. Where can I get one? Quote Link to comment
Crashtd420 Posted May 18, 2017 Report Share Posted May 18, 2017 This should work?... do they look like this...? Saw the same part number on ebay... $14 shipped from red line.... Quote Link to comment
d.p Posted May 18, 2017 Author Report Share Posted May 18, 2017 I am down to do that, but with what? Cereal box? Guess I can buy gasket material and make it from that as well. Quote Link to comment
datzenmike Posted May 18, 2017 Report Share Posted May 18, 2017 Just about anything even store bought gasket material. Take a good look at the original gasket, isn't much better than cereal box. Get a $2 hole punch from the dollar store and away you go. Quote Link to comment
Crashtd420 Posted May 18, 2017 Report Share Posted May 18, 2017 That's one way.... auto parts store sells a make your own gasket matterial.... just make sure it's ok for gas.... I remember seeing 2 different types when I bought some.... Quote Link to comment
datzenmike Posted May 18, 2017 Report Share Posted May 18, 2017 My thermostat housing and cover are cereal box, as is the water pump. Would not use on manifolds or exhaust. Oil pan gasket needs to be much thicker and crushable. Quote Link to comment
d.p Posted May 18, 2017 Author Report Share Posted May 18, 2017 Well I have all the other gaskets so I don't need to make those and the carb one should be easy enough with that red block plate that goes inbetween the carb and manifold. I can just trace that. Quote Link to comment
datzenmike Posted May 18, 2017 Report Share Posted May 18, 2017 Hole punch for the bolts and to get a start with scissors for the two barrels. Make two. Put on dry never use sealant it's not needed and or you'll never get them off again. 1 Quote Link to comment
