ironear Posted March 7, 2017 Report Share Posted March 7, 2017 Hi guy! I'm just replaced old carburettor with Hitachi SU carburettor. but I don't know Where does this breath hose connect...? and the pipe for fuel return too.Thank you! Quote Link to comment
datzenmike Posted March 7, 2017 Report Share Posted March 7, 2017 The return line connects to the fuel return line, I don't think your year of car has it. You'll have to run without it. It's purpose is to recirculate unused fuel back to the tank and keep cooler fuel in the lines. This reduces fuel boiling from excessive engine and under hood temperatures. The block vent hose connects to the PCV valve between the carbs on the intake. See that hose under the plug with the blue cap on the manifold? 1 Quote Link to comment
Dolomite Posted March 7, 2017 Report Share Posted March 7, 2017 Couple small points... 1. Those carbs run better with the pcv hooked up and your engine bay wont get covered in oil. 2. This is more important, you're asking for disaster with your vent hoses routed like they are. If you sink a float, you're going to bathe a hot manifold in fuel. Worse if it had a little carb backfire during such an event, Hitachi su carbs have little hiccups through the carb fairly frequently when cold if your chokes aren't even. I'd get longer pieces of fuel line and go over the motor so any leaked fuel will just go on the ground. Quote Link to comment
ironear Posted March 8, 2017 Author Report Share Posted March 8, 2017 Thank you for your suggestion Dolomite. Datzenmike, Could you advise me where is the return pipe from carburettor? I really don't know where is it. below is mine carb setup on Datsun A15 in ford Anglia engine bay. Quote Link to comment
Draker Posted March 8, 2017 Report Share Posted March 8, 2017 There is no return, just over flow ports. Quote Link to comment
