bob3d Posted December 5, 2016 Report Share Posted December 5, 2016 I have a 78 b210 my mother bought new. It's in excellent condition and I enjoy keeping it that way. I am wondering why the aux butterfly valve on the secondary doesn't open when the secondary on the throttle body opens. It has that little arm with the disc shaped weight on the side of the carb and it moves easily and opens the valve. Apparently it's operated by airflow/vacuum at high rpms. Car runs great but i'm not getting proper secondary operation. Please help. Quote Link to comment
datzenmike Posted December 5, 2016 Report Share Posted December 5, 2016 Um... in order to see it working under heavy load you would have to take the hood and air filter off and ride in the engine compartment. Revving it in neutral, no matter how high, is rarely enough. It's probably just fine. Quote Link to comment
kelowg Posted December 5, 2016 Report Share Posted December 5, 2016 Just make sure it moves freely. maybe some spray lube. Quote Link to comment
bob3d Posted December 5, 2016 Author Report Share Posted December 5, 2016 Thanks, so I hope its working under a load then I'll try to think of a way to "witness it" . It moves freely. Might mount a small video camera to see if the arm moves while driving. Quote Link to comment
datzenmike Posted December 5, 2016 Report Share Posted December 5, 2016 Yes. Someone did this with an SU carb. All you need is to see the linkage on the outside move. Quote Link to comment
bob3d Posted December 5, 2016 Author Report Share Posted December 5, 2016 Got a better idea. Costco has an inspection camera on sale with a 3 foot optical cable. I'll run it through the firewall. Going there now. Followup- I zip tied the fiber optic to view the linkage, taped the monitor to my windshield and drove around. The camera showed the secondary flapper arm was responding correctly when I floored it. 1 Quote Link to comment
datzenmike Posted December 6, 2016 Report Share Posted December 6, 2016 As it should. It's hard to load the engine enough in neutral and revving it. Quote Link to comment
Cosmonaut Posted December 6, 2016 Report Share Posted December 6, 2016 Your mother mayhave seldomely used the secondaries...Probably varnished up the secondary jet & or secondary inlet. Time for a carburator rebuild? Quote Link to comment
