flatcat19 Posted May 9, 2017 Report Share Posted May 9, 2017 She says you won't let her watch them. I'm standing by the cool story your daughter has spoken. Quote Link to comment
hobospyder Posted May 9, 2017 Report Share Posted May 9, 2017 Ok. No idea what movies then. But if it was cassettes I won't let her watch them because there is no way to watch them Quote Link to comment
Scgreen620 Posted May 10, 2017 Author Report Share Posted May 10, 2017 What's your favorite Disney movie hobo? Quote Link to comment
hobospyder Posted May 10, 2017 Report Share Posted May 10, 2017 What's your favorite Disney movie hobo? tron:legacy 1 Quote Link to comment
hobospyder Posted May 10, 2017 Report Share Posted May 10, 2017 It's a good music video 1 Quote Link to comment
Scgreen620 Posted May 12, 2017 Author Report Share Posted May 12, 2017 Lol never seen it .. Just reminds me of west coast customs .. The tron based build Quote Link to comment
hobospyder Posted May 12, 2017 Report Share Posted May 12, 2017 it's a really good music video, i want to recommend watching it but you have to know i'm a tron fanboy Quote Link to comment
Scgreen620 Posted May 13, 2017 Author Report Share Posted May 13, 2017 So guys real quick before I mess with my truck myself just wondering what do you guys think.. I totally forgot I had the ebrake on ... I wasn't able to see it because I was driving at night .. Drove for 3 miles .. Did not feel the truck slow or trying to slow me down got off the freeway, was on the off ramp pressed the brakes and all of a sudden I felt like there was no pressure the pedal dropped close the floor, pumped the pedal and it started braking ... But now in order to brake I have to push the pedal almost all the way to the floor ... Did not smell anything burning and did not see any fluid come out the cylinders front or back ..... Has anyone had this happen before ? 1 Quote Link to comment
Charlie69 Posted May 13, 2017 Report Share Posted May 13, 2017 Adjust rear brakes and re bleed system. You probably over heated the rear brakes. New brake fluid is a good idea which will be replaced by a good bleeding of all 4 brakes. Bleed until all air is out and the fluid coming out runs clear at each wheel starting at the farthest wheel from the master cylinder.. DOT 3 brake fluid. 3 Quote Link to comment
Scgreen620 Posted May 13, 2017 Author Report Share Posted May 13, 2017 Had a feeling this was the problem .... Thanks Charlie did not want to worry to a point where I take it apart up the the cylinders Quote Link to comment
Scgreen620 Posted May 13, 2017 Author Report Share Posted May 13, 2017 Glad you were up lol Quote Link to comment
hobospyder Posted May 13, 2017 Report Share Posted May 13, 2017 furthest wheel is usually drivers side rear. at least on my 73 and 76 it is 1 Quote Link to comment
Scgreen620 Posted May 13, 2017 Author Report Share Posted May 13, 2017 Should I replace the brake shoes? Or front brakes? Or not really worry about it ? Quote Link to comment
hobospyder Posted May 13, 2017 Report Share Posted May 13, 2017 Should I replace the brake shoes? Or front brakes? Or not really worry about it ? do this first: Adjust rear brakes and re bleed system. You probably over heated the rear brakes. New brake fluid is a good idea which will be replaced by a good bleeding of all 4 brakes. Bleed until all air is out and the fluid coming out runs clear at each wheel starting at the farthest wheel from the master cylinder.. DOT 3 brake fluid. and see how she brakes after all is said and done. 1 Quote Link to comment
Scgreen620 Posted May 13, 2017 Author Report Share Posted May 13, 2017 You guys don't think I should change the cylinders as well right ? Cuz they are new about 6 months old front and rear Quote Link to comment
hobospyder Posted May 13, 2017 Report Share Posted May 13, 2017 You guys don't think I should change the cylinders as well right ? Cuz they are new about 6 months old front and rear ok, again, do this first: Adjust rear brakes and re bleed system. You probably over heated the rear brakes. New brake fluid is a good idea which will be replaced by a good bleeding of all 4 brakes. Bleed until all air is out and the fluid coming out runs clear at each wheel starting at the farthest wheel from the master cylinder.. DOT 3 brake fluid. and see how she brakes after all is said and done. don't need to even take the wheels off at this point 1 Quote Link to comment
Scgreen620 Posted May 13, 2017 Author Report Share Posted May 13, 2017 I got carried away a little ... Now I have the list took the wheels off checked the rear drums seem fine I do need to adjust them tho... Took the front wheels off noticed I have a wobble on one and I hear metal grind noise .. I'm thinking it's the bearings so now that I'm going to fix the bearings .. I'm going to do slotted rotors saw some on rock auto .. And since the brakes are wearing off all messed up, I'll replace those as well .... Saw some eBay slotted and drilled rotors for 100 bucks .. Their for the 86 hardbody ... Has anyone used those before ? Another thing my driver side torsion bar has a wiggle is there bushings I can use to fix this issue? Quote Link to comment
hobospyder Posted May 14, 2017 Report Share Posted May 14, 2017 how did this go from bleed and adjust the brakes to "fuck it i'm doing disk up front"? or do you already have disk up front? 1 Quote Link to comment
Scgreen620 Posted May 14, 2017 Author Report Share Posted May 14, 2017 It came with disk but the hardbody v6 calipers sound way better ... Went to the junk yard.... Installed them never changed the rotors or the pads all I did was install and bleed .. It was a daily ..... now that I have a work van I only drive it when I miss it which is every 3 day lol 1 Quote Link to comment
hobospyder Posted May 14, 2017 Report Share Posted May 14, 2017 oh, well now that i'm on computer and actually paying attention, this is a 78 so comes stock with front disk. ok, i see now. carry on 2 Quote Link to comment
flatcat19 Posted May 15, 2017 Report Share Posted May 15, 2017 You will receive zero benefit from slotted/drilled rotors. Just buy regular rotors from a quality brand and save a few bucks. 1 Quote Link to comment
Scgreen620 Posted May 16, 2017 Author Report Share Posted May 16, 2017 Ebay drilledand slotted rotors with pads 100 bucks .. Doesn't sound too bad lol 1 Quote Link to comment
flatcat19 Posted May 16, 2017 Report Share Posted May 16, 2017 Centric rotors...$30 each. Stop Tech pads...$40. RA. There's your $100 with better performance than some generic, throw away crap an eBay some buyer got duped into buying...because...hey, slots and holes drilled in my rotor looks fast. Drilled holes in rotors weaken them. And any "performance" rotor worth a damn cost more than that price. Your truck, your money. I speak from experience though. You ever fix that "noise" you couldn't find? 1 Quote Link to comment
