DatMo Posted August 30, 2016 Report Share Posted August 30, 2016 So on my 72 510, I want to get rid of the linkage and switch over to the much better cable style throttle. I've purchased a 36inch lokar cable kit but I'm not sure how to connect it to my dual 40 dellorto carbs. Anyone have pictures or could explain how they hooked it up? Thanks! Quote Link to comment
G-Duax Posted August 30, 2016 Report Share Posted August 30, 2016 Need pictures of your dual carb manifold & carbs to see what options you have. Will be a lot easier than asking you 20 questions. 1 Quote Link to comment
Stoffregen Motorsports Posted August 30, 2016 Report Share Posted August 30, 2016 Dual SU's or dual Mikuni's or Webers? If SU's, I've got nothin for ya. If dual Mikunis, search Ratsun for centerpull linkage. Quote Link to comment
DatMo Posted August 30, 2016 Author Report Share Posted August 30, 2016 Need pictures of your dual carb manifold & carbs to see what options you have. Will be a lot easier than asking you 20 questions. Not a problem. Will get em right now. Quote Link to comment
DatMo Posted August 30, 2016 Author Report Share Posted August 30, 2016 Dual SU's or dual Mikuni's or Webers? If SU's, I've got nothin for ya. If dual Mikunis, search Ratsun for centerpull linkage. Also just read that thread but seems to be that you need to either fab one which I don't think I can do, or get one from a Toyota that I'm never gonna find. Quote Link to comment
Ranman72 Posted August 31, 2016 Report Share Posted August 31, 2016 here is my set up dave at rebello had to build a piece for the srea between the carbs hopefully you can zoom in and see something that helps inside the car at the pedal 1 Quote Link to comment
Ranman72 Posted August 31, 2016 Report Share Posted August 31, 2016 this was a mr gasket cable which served its purpose but I did change it out to a lokar which is a superior cable to mr gasket they have nice aluminum ends and a better thinner cable i will post some pics when photo bucket quits being stupid [/url] Quote Link to comment
DatMo Posted August 31, 2016 Author Report Share Posted August 31, 2016 So I've just ordered a piece from pierce on Amazon that says they're for dual carbs and looks like what you've got there Rahman. As far as return springs, where'd you hook yours? Quote Link to comment
Ranman72 Posted September 1, 2016 Report Share Posted September 1, 2016 So I've just ordered a piece from pierce on Amazon that says they're for dual carbs and looks like what you've got there Rahman. As far as return springs, where'd you hook yours? i hooked them to a heat shield i drilled a hole in i run 2 because if one breaks you cant pull the pedal back manually like you can with linkage Quote Link to comment
DatMo Posted September 1, 2016 Author Report Share Posted September 1, 2016 i hooked them to a heat shield i drilled a hole in i run 2 because if one breaks you cant pull the pedal back manually like you can with linkage That's a great tip I'll have to probably drill into my heat shield. I ordered the dual weber/mikuni piece from pierce but not that bottom mount plate. I'll have to see what happens if I need that place or not 1 Quote Link to comment
Stoffregen Motorsports Posted September 1, 2016 Report Share Posted September 1, 2016 Can you give us a link to the part you bought from Pierce? Would probably help the next guy with the same question. Quote Link to comment
