takeatoke Posted October 21, 2008 Report Share Posted October 21, 2008 Just looking for some opinions here. Like the title says i have a 79 620 King Cab. I have had it for about 2 almost 3 years. Right now the cab and bed are sitting in my basement, and the chassis in the garage waiting to be sand blasted. I have browsed around the forums for a couple weeks and got some ideas. Just wanting to ask some "experience" what should i do first? ( other than the motor Thats covered:D:D) Should i go ahead and replace the everything on the chassis ,lowering,suspension parts or what ever just shoot me some ideas on what you would do if your cab and bed where sitting beside your truck?? :confused: Thanks Jason Quote Link to comment
yello620 Posted October 22, 2008 Report Share Posted October 22, 2008 What are your plans for the truck? Plan to lower it? How far? Lift it? If i was working with a frame, I would start with getting the carrier bearing crossmember so that it does not hang below the main frame rails, I would also trim up the mounting tabs that are on the frame at the transmission crossmember. I would also make the necessary mods to make the exhaust tuck inside the frame rails and not way below the rails like factory. Jason Quote Link to comment
Cuts metal like mad Posted October 22, 2008 Report Share Posted October 22, 2008 Do whatever makes thing easier... sorry for the simple answer, but its really that simple. If you're going to static drop it, lower it after its back together, if your gonna bag it or do 4 link or anything that requires cutting, grinding, welding, etc., do it with the body and bed off... do all your brake work before reassembling it too, easier when its more accessible. Certainly do the ball joints, and bushings before the body goes back on. Can't really tell you what to do about the drivetrain... since you didn't tell us what it is your doing with it... but if it doesn't require modifications to the body, install it while the body is off. Since you've gone through the trouble of pulling the body off already, make the thing BETTER than new. Thats about all I can think of at the moment... but theres PLENTY you can do... Quote Link to comment
peanut2425 Posted October 22, 2008 Report Share Posted October 22, 2008 notch it, 4 link it, bag it, :D, u should probly body drop it too while your at it :thumbsup: . That's just what I would do anyway Quote Link to comment
]2eDeYe Posted October 22, 2008 Report Share Posted October 22, 2008 What these guys said ^ Figure out what you want from your truck and make a plan. Replace all the soft parts; bushings, grommets, etc. Quote Link to comment
Farmer Posted October 22, 2008 Report Share Posted October 22, 2008 (edited) Only thing I got, is to take alot of pictures of this build, for us picture freaks:lol: Heres my http://forum.ratsun.net/showthread.php?t=3745 Project link. I not doing frame off but front end replacement. Its better to replace all new at one time then to do it one at a time. Larry Edited October 22, 2008 by Farmer Quote Link to comment
takeatoke Posted October 22, 2008 Author Report Share Posted October 22, 2008 ]2eDeYe Does those Titan wheels bolt right on or do they need shimmed or modded in anyway? (prolly been asked that a million times lol ) Quote Link to comment
takeatoke Posted October 23, 2008 Author Report Share Posted October 23, 2008 Only thing I got, is to take alot of pictures of this build, for us picture freaks:lol: Heres my http://forum.ratsun.net/showthread.php?t=3745 Project link. I not doing frame off but front end replacement. Its better to replace all new at one time then to do it one at a time. Larry Ill be getting some pics up this weekend. Gotta go buy some batteries and im to lazy after i get off work :sleep::sleep: Quote Link to comment
]2eDeYe Posted October 23, 2008 Report Share Posted October 23, 2008 That it has :D You can start at the FAQ in my sigline ;) Quote Link to comment
takeatoke Posted October 23, 2008 Author Report Share Posted October 23, 2008 What are your plans for the truck? Plan to lower it? How far? Lift it? Jason Definitely lower it. I would really like to use Fineline's Setup http://forum.ratsun.net/showthread.php?t=1262 but im going to read some more would like to know some pros and cons for both air bags and the coilover setup. Prolly be adding about 60 to 80 hp more to the l20b maybe more. 280zx 5 speed dont know about rear-end yet. Does anyone have the specs on the disc brake brackets,I can make about anything @ work if it is metal or aluminum. and do i need to upgrade my front disc brakes or will those be ok?? I really havent had time to sink my teeth into this forum yet so please forgive if this has been asked a million times:o Quote Link to comment
yello620 Posted October 23, 2008 Report Share Posted October 23, 2008 Does anyone have the specs on the disc brake brackets,I can make about anything @ work if it is metal or aluminum. and do i need to upgrade my front disc brakes or will those be ok?? I really havent had time to sink my teeth into this forum yet so please forgive if this has been asked a million times:o I think that the caliper design of the 78/79 620 trucks really sucks, and there are far superior factory parts that can be bolted on in place of the 79 crap. Consider installing Nissan Hardbody D21 drop spindles and brakes from a V-6 truck. You get 2 inch drop, larger vented rotors, superior design caliper and dual pistons per caliper. Sorry, no forgiving if you havent used the seach function.:lol: Quote Link to comment
takeatoke Posted October 26, 2008 Author Report Share Posted October 26, 2008 been a little busy this weekend, But got some pic of the 620. Now i cant find the f-n usb cable:mad:. i think it is in the car,and wifey is gone to a friends house. I have found some other pics of the truck before it was took apart I should have the others up a little later tonight. [/img] Quote Link to comment
takeatoke Posted October 28, 2008 Author Report Share Posted October 28, 2008 How it sits now. [/img] [/img] Quote Link to comment
