kwoo510 Posted October 17, 2008 Report Share Posted October 17, 2008 I've never removed a torsion bar before. I imagine I need to relief stress from the torision bar before lossening any bolts. How do you relief the stress from the torsion bar? Quote Link to comment
]2eDeYe Posted October 17, 2008 Report Share Posted October 17, 2008 Jack the truck up so the wheels are not touching the ground. Quote Link to comment
xtrmemtnmn Posted October 17, 2008 Report Share Posted October 17, 2008 Yeah what ^he said Quote Link to comment
datzenmike Posted October 17, 2008 Report Share Posted October 17, 2008 (edited) You will still have to back off the lock nut and then loosen the torsion bar anchor bolt nut located at the rear of the bar. Just forward of this is a dust boot, slide it forward to expose a snap ring. Remove the snap ring and note position of the anchor arm so you can replace in the same position. Slide the torsion bar and the attached anchor arm to the rear to remove. I had to clamp a pair of vice grips along the bar and tap with a hammer to loosen it. Edited October 18, 2008 by datzenmike Quote Link to comment
SickDrift Posted October 18, 2008 Report Share Posted October 18, 2008 I've never removed a torsion bar before. I imagine I need to relief stress from the torision bar before lossening any bolts. How do you relief the stress from the torsion bar? I had this same concern, I didnt want to lose my face beneath my truck, but as the others said jack up the truck and let the wheels hang loose, you will have no probs. Tension is only on that bar when the weight is on the wheels. And as mike said, you must remove the ring ro remove the bracket that holds the torsion bar. Quote Link to comment
