ShaneLovesDatsuns Posted March 18, 2016 Report Share Posted March 18, 2016 Anyone else ever get oil in all the spark plugs and wires? Someone tried to tell me it could be a valve cover gasket? Which was confusing. Anyhow. I'm just curious if anyone else has experienced this and how they remedied it on an L series. I changed my plug wires today And that's when I realized it. I forgot to take pictures at the time but I did take pictures of the plug wires a while ago, you can still see some oil. It was in all 4 plugs the two inside worse than the two outside. This is an L18 engine in my 521 if that matters. Quote Link to comment
Angela Posted March 18, 2016 Report Share Posted March 18, 2016 I've got the same thing on my L16 right now. My mechanic suggested I might try tightening down the spark plugs a bit. I'd be curious to hear how other's weigh in on this issue as well. [/url] Quote Link to comment
KoHeartsGPA Posted March 18, 2016 Report Share Posted March 18, 2016 valve cover gasket. 1 Quote Link to comment
datzenmike Posted March 18, 2016 Report Share Posted March 18, 2016 DON'T over tighten them. Use NGK plugs for perfect fit, not Champion. Oil can only get in or on the wires from external leaks. Like valve cover gasket, fuel pump gasket, timing cover gasket. 1 Quote Link to comment
banzai510(hainz) Posted March 18, 2016 Report Share Posted March 18, 2016 mine leak from the holes also. just periodically clean them. Don't worry it s L motor. Rebuild after awhile but they all will do it eventually buy 2 set of NGK wire sets from Amazon or where ever NE64 is the wire set 1 Quote Link to comment
ShaneLovesDatsuns Posted March 18, 2016 Author Report Share Posted March 18, 2016 Thank you everyone, getting ready to tear the valve cover off now. I'm going to my plugs and my gasket today, hopefully that wicked misfire goes away. I'll take nite pictures if the ignition system and stuff when I get down to it. I'm going to ask really stupid questions like what gap spark plug do you recommend for "insert ignition system here." Thanks again everyone.. Quote Link to comment
Angela Posted March 19, 2016 Report Share Posted March 19, 2016 DON'T over tighten them. Use NGK plugs for perfect fit, not Champion. Oil can only get in or on the wires from external leaks. Like valve cover gasket, fuel pump gasket, timing cover gasket. I haven't tightened or messed with anything yet so no damage done there. I use ONLY NKG anyway so that's good. I will check the valve cover gasket, fuel pump gasket, timing cover gaskets for the issue. Thanks! 2 Quote Link to comment
