silentcry1 Posted March 5, 2016 Report Share Posted March 5, 2016 I had a question. I found a good 1973 Datsun truck in the junk yard. I have a 1970 Datsun 521 truck. I wanted to know if the suspensions are the same and if it will fit my truck. Also does any other parts from the 1973 truck fit my truck. 1 Quote Link to comment
flatcat19 Posted March 5, 2016 Report Share Posted March 5, 2016 Hit or miss. Being an early 620, some stuff MIGHT, some stuff doesn't. What are you looking to get that you need? 1 Quote Link to comment
thisismatt Posted March 5, 2016 Report Share Posted March 5, 2016 So you want to swap your crappy kingpins and drum brakes for some crappy kingpins and drum brakes? 6 Quote Link to comment
flatcat19 Posted March 5, 2016 Report Share Posted March 5, 2016 So you want to swap your crappy kingpins and drum brakes for some crappy kingpins and drum brakes? Hory sheet. I'm rolling over here. Kudos. 2 Quote Link to comment
MicroMachinery Posted March 5, 2016 Report Share Posted March 5, 2016 That's rich. 1 Quote Link to comment
DanielC Posted March 5, 2016 Report Share Posted March 5, 2016 I have found that the parts used on early 620 trucks in some cases are the same size, but the fasteners, (nuts and bolts) on 521 trucks are imperial, specifically a SAE standard, and 620 trucks are metric. A rear wheel cylinder off a 521 fits a 620, I think, and a rear wheel cylinder off a 620 will fit a 521. However, the rear wheel cylinder in a 521 is held to the backing plate with 5/16-24 studs, and nuts, and the rear wheel cylinder on a 620 is held with M8-1.25 studs and nuts. The flare nut for the brake line is 3/8-24 on a 521, and M10-1.0 on the 620. I may be off on the exact metric thread size, I have 521 trucks, and I have not had a 620 right beside it to try to swap parts back and forth between the two different models. Some metric sizes convert to inches easily. 3/4 is within a few thousands of an inch to 19 mm. 5/16 is close to 8 mm. I believe brake drums will interchange from 320, 520, 521, 620, and even some 720 rear drums. I could be wrong on that. 3 Quote Link to comment
thisismatt Posted March 5, 2016 Report Share Posted March 5, 2016 Daaaaamn Daniel, back at it again with the helpful info! 1 Quote Link to comment
4perrev Posted March 10, 2016 Report Share Posted March 10, 2016 Dude, that is too funny up there with the crappy to the crappy and picture. Sweet. Seriously, if you have a 521, you should just do the disc brake conversion! Quote Link to comment
