Outta_OC Posted March 2, 2016 Author Report Share Posted March 2, 2016 Yeah it's running great after the new plugs and working thermostat... Hah. Revs all the way through now. The plugs were gapped at .39 I think... I guess I should pull them and gap to .32? Quote Link to comment
Doctor510 Posted March 3, 2016 Report Share Posted March 3, 2016 Yeah it's running great after the new plugs and working thermostat... Hah. Revs all the way through now. The plugs were gapped at .39 I think... I guess I should pull them and gap to .32? Do you have points or is the ign electronic? I'm blind here I do not remember seeing what vehicle you have. What plugs are you using? Kind of important info, thanks 1 Quote Link to comment
datzenmike Posted March 3, 2016 Report Share Posted March 3, 2016 NGK plugs only. B6ES and close to 0.032" gap with Pertronix. If you get a working EI dizzy and proper coil it much wider. Too wide a gap and the spark will start looking for an easier path to ground. Always maintain your ignition wires,rotor and cap so that the plug gap IS the easiest path to ground. 1 Quote Link to comment
Doctor510 Posted March 3, 2016 Report Share Posted March 3, 2016 IF electronic, use the BP6ES 11, gap at .039" Quote Link to comment
Outta_OC Posted March 3, 2016 Author Report Share Posted March 3, 2016 I put the champion equivalent due to autozone not having the ngk in stock. I do have the pertronix igniter - so .039 is perhaps ok? The thing is running so much better now it's amazing Quote Link to comment
datzenmike Posted March 4, 2016 Report Share Posted March 4, 2016 NGK plugs only. B6ES and close to 0.032" gap with Pertronix. If you get a working EI dizzy and proper coil it much wider. Too wide a gap and the spark will start looking for an easier path to ground. Always maintain your ignition wires,rotor and cap so that the plug gap IS the easiest path to ground. 0.039 is too wide. 0.032 is better for what you have now. The Pertronix system is basically stock output but without having points. 1 Quote Link to comment
Doctor510 Posted March 4, 2016 Report Share Posted March 4, 2016 Pertronix, set plugs at .035" 1 Quote Link to comment
banzai510(hainz) Posted March 4, 2016 Report Share Posted March 4, 2016 When you get a chance always run the NGK/Nippondenso plugs. I notice on the autolites the thread pitch is slightly different and always has a MOFO time pulling those back . Thought the plug was going to snap. I never gap my plugs and most are .032 from the factory. Never had a proplem matter of fact I just pull them out of heads I gets over the years clean them up and run them 1 Quote Link to comment
Outta_OC Posted March 4, 2016 Author Report Share Posted March 4, 2016 My girlfriend is getting tired of me spending my satudays under the hood... Hahaha... Thanks for all the helps guys, I'll pull the plugs and gap down a bit Quote Link to comment
KoHeartsGPA Posted March 4, 2016 Report Share Posted March 4, 2016 She doesn't love you then...plenty pussy in Los Angeles, ditch her! Quote Link to comment
datzenmike Posted March 5, 2016 Report Share Posted March 5, 2016 My girlfriend is getting tired of me spending my satudays under the hood... Hahaha... Thanks for all the helps guys, I'll pull the plugs and gap down a bit Yup, pick one. loose the other. Oil and water don't mix. 1 Quote Link to comment
