xUltra510 Posted January 28, 2016 Report Share Posted January 28, 2016 Yet again another project, however, this project isn't mine, it's my friends. I got him into Datsuns and we found him a truck for a cool $400 plus $50 for the trailer. Original owner's plans were to turn it into a crawler. First oics. Cleaning Day Engine was a bit messy. Note: That pos battery was taken out seconds after taking this oic. Goal: To make it a daily driver. The truck was left out rotting in the sun for over 8 years. However, most of the truck is stock. The gas tank was full of rust(repaired), but the oil and spark plugs were literally new. We gave the truck a jump start and poured some gas in the carburetor and Voilà it started!! We began by cleaning out the truck from the outside, giving it a good scrub with a power washer (oics of this soon). We then went and bought a nice battery to get it running again but it had a couple problems. The timing was/currently is off. We will began restoring the engine this week and a lot of oics are expected. 2 Quote Link to comment
5t341tH Posted January 28, 2016 Report Share Posted January 28, 2016 nice pick up for cheap. i see you are also missing the lower part on the front fenders like mine did 1 Quote Link to comment
banzai510(hainz) Posted January 28, 2016 Report Share Posted January 28, 2016 Be amazed how soem people cant keep a simple rig running. timming EZ 5 min job. unless oil pump drive off shit I would buff it out, put new tires of the same type(cooper trendsetters are close to that on Tires Easy.) Lower it and call it good till . Work out most of the bugs as this is old and soem hydralic parts might start failing since it sitting for so long. ck trans oil also 2 Quote Link to comment
S30Jay Posted January 30, 2016 Report Share Posted January 30, 2016 Looks like a solid truck. I'm in northern Pennsylvania so I'm not used to hearing about vehicles rotting in the sun, I consider sun the least harmful element my cars face. Salt is brutal. Good luck on your buildup! 1 Quote Link to comment
