nissan720 Posted December 8, 2015 Report Share Posted December 8, 2015 has anyone started making engine mounts for the conversion of fuel injected motors to the 720? 1 Quote Link to comment
datzenmike Posted December 8, 2015 Report Share Posted December 8, 2015 The later 720 and the D-21 Hardbody both had Z24i EFI engines. No changes needed. The KA24E and KA24DE have been successfully swapped into the 720. 1 Quote Link to comment
nissan720 Posted December 8, 2015 Author Report Share Posted December 8, 2015 so will the engine drop in without any modificationn.bolt holes should line up? 1 Quote Link to comment
Lockleaf Posted December 8, 2015 Report Share Posted December 8, 2015 Which engine do you refer too? 1 Quote Link to comment
nissan720 Posted December 8, 2015 Author Report Share Posted December 8, 2015 i am going to use an engine out of a 1995 nissan pickup.ka24e 1 Quote Link to comment
Rjawm Posted December 8, 2015 Report Share Posted December 8, 2015 Technically, yes they bolt up. But they do so at the wrong angle, the relation of the engine mount to the frame angle is different between the two. The D21 has a steeper angle on the frame than the 720. If the original KA mounts are used they cause the 720 isolators to bind up in an extreme preloaded condition. You can modify the angle of the KA mounts to match the NAPz and not have the binding issue. 1 Quote Link to comment
datzenmike Posted December 8, 2015 Report Share Posted December 8, 2015 This often happens. YOU know what you have and want to do but WE don't. For good communication, you need to include all the information about what you are trying to do. 1 Quote Link to comment
nissan720 Posted December 8, 2015 Author Report Share Posted December 8, 2015 i simply want to put that ka24e engine from the 1995 nissan pickup in my 1984 720.just thought it might be someone out there making the mounts.to make just a drop in without any complications. 1 Quote Link to comment
datzenmike Posted December 8, 2015 Report Share Posted December 8, 2015 http://community.ratsun.net/topic/30277-z24-to-ka24de-any-write-ups/ http://community.ratsun.net/topic/19011-ka24e-or-de-into-1984-nissan-720/ 1 Quote Link to comment
nissan720 Posted December 8, 2015 Author Report Share Posted December 8, 2015 thanks datzenmike thats the info i needed. 1 Quote Link to comment
datzenmike Posted December 8, 2015 Report Share Posted December 8, 2015 Maybe???... http://community.ratsun.net/classifieds/item/5568-620-ka24-engine-swap-mounts/ Quote Link to comment
