banzai510(hainz) Posted March 9, 2016 Report Share Posted March 9, 2016 Looks like a common 510/521 set up with a bypass outlet. Some had these some didn't. the hard part is how you plug the metal line???????? I assume you cked the wire for power with the key ON????? rockauto has a Airtex wells brand that looks like the one you need unless you got this one already just has a bullet end instead of a lug nut just have someone send you theres with the sender already in and get a gasket that goes to the head and be done with this Quote Link to comment
Motschrocker Posted March 9, 2016 Author Report Share Posted March 9, 2016 yeah the airtex is the one I got and it did not work. Should I just post in a parts wanted section and see if someone has a therm housing laying around? It was a while ago that I messed with it but yes I believe I determined the sending unit was the problem. When I ground the wire the gauge would move. Just wont do anything when attached to sending unit. Quote Link to comment
bilzbobaggins Posted March 9, 2016 Report Share Posted March 9, 2016 http://m.ebay.com/itm/Datsun-240Z-Thermostat-Housing-1970-1972-OEM-NEW-/231847572615?nav=SEARCH this one appears to have a spot for a bypass nipple and for a sending unit. Quote Link to comment
banzai510(hainz) Posted March 9, 2016 Report Share Posted March 9, 2016 fuck 38bucks then you need the hex and the sender.$$$$ Quote Link to comment
Motschrocker Posted March 10, 2016 Author Report Share Posted March 10, 2016 Well i do have the sending unit i bought thinking it might be correct. 38 bucks is steap but if that is the correct size it could work. I need to figure something out so i can drive it and keep an eye on the temp. Quote Link to comment
bilzbobaggins Posted March 14, 2016 Report Share Posted March 14, 2016 there is a 5 dollar lower thermostat housing in the asssifided. two bolt, two outlets. 1 Quote Link to comment
Motschrocker Posted March 15, 2016 Author Report Share Posted March 15, 2016 Dang right after i bought one on ebay. For 5 bucks ill get two in case i mess one up. Quote Link to comment
bilzbobaggins Posted March 15, 2016 Report Share Posted March 15, 2016 Dang right after i bought one on ebay. For 5 bucks ill get two in case i mess one up. cuz if you dont i am :) Quote Link to comment
KoHeartsGPA Posted March 17, 2016 Report Share Posted March 17, 2016 Heat treatment with a small torch maybe? Quote Link to comment
