theeoracle Posted June 5, 2015 Report Share Posted June 5, 2015 I recently purchased an l20b for a rebuild. when i took off the valve cover there was no camshaft gear bolt. I'm pretty sure there's suppose to be one. I want to know what bolt and washers would fit in the cam. I don't have the bolt and washers that are in the picture. Quote Link to comment
john510 Posted June 5, 2015 Report Share Posted June 5, 2015 Dont use anything but the one that should be there ! junkyard ? any L series motor will have the one you need. Quote Link to comment
Doctor510 Posted June 5, 2015 Report Share Posted June 5, 2015 USE cam bolt and associated washers from any L series motor and FP drive bucket if you have a mech FP. DO NOT attempt to run the motor w/o them. I have all the parts available used and in good shape if you need them. Quote Link to comment
theeoracle Posted June 5, 2015 Author Report Share Posted June 5, 2015 USE cam bolt and associated washers from any L series motor and FP drive bucket if you have a mech FP. DO NOT attempt to run the motor w/o them. I have all the parts available used and in good shape if you need them. sure i could use them. how much? Quote Link to comment
datzenmike Posted June 6, 2015 Report Share Posted June 6, 2015 Take this to private message please. How is the fuel pump driven? There should be a an eccentric for the fuel pump arm to ride on. You will need one if you plan to run the mechanical pump. Quote Link to comment
theeoracle Posted June 6, 2015 Author Report Share Posted June 6, 2015 It is mechanically driven. So yea i guess i need an eccentric and the bolt. Anyone got one? USE cam bolt and associated washers from any L series motor and FP drive bucket if you have a mech FP. DO NOT attempt to run the motor w/o them. I have all the parts available used and in good shape if you need them. for some reason it says "The member Doctor510 cannot receive any new messages" dont know why Quote Link to comment
datzenmike Posted June 6, 2015 Report Share Posted June 6, 2015 Well there's... http://community.ratsun.net/classifieds/category/4-engine/?sort_key=date_added&sort_order=desc ... and... http://community.ratsun.net/topic/66553-classifieds-canby-delivery-only/ but not here...http://community.ratsun.net/topic/66598-camshaft-gear-bolt-help/ Quote Link to comment
